Tyres
lukey4x4
Tyres
Post by lukey4x4 » Tue Jun 21, 2016 1:38 pm
Hello lads , another tyre question sorry lol , av got some of them fatboy deep dish alloys for my sj n just need a bit of info , iam looking to buy some tyres but bot sure on what i need my sj has the 1.6 spi engine, and running on 410 axels n diffs , its spoa with nothing cut out , shall i play safe n but 31s or would 33s be ok whats people thorts , thanks
Re: Tyres
Post by Jordi » Tue Jun 21, 2016 3:08 pm
What size wheels have you got?
What off set are they?
Did you move the axles forwards / backwards when you did SPOA?
lukey4x4
Re: Tyres
Post by lukey4x4 » Tue Jun 21, 2016 4:37 pm
There 15x10 jordi mate not to sure on the axel bin moved it was already spoa when i bought it
lukey4x4
Re: Tyres
Post by lukey4x4 » Tue Jun 21, 2016 9:06 pm
Any recommendations where to buy from aswell ,
SherwoodNash
Re: Tyres
Post by SherwoodNash » Tue Jun 21, 2016 9:11 pm
lukey4x4 wrote:Any recommendations where to buy from aswell ,
Camskill's are pretty hard to beat for price and quick delivery, very helpful on the phone too.
http://www.camskill.co.uk/
Re: Tyres
Post by dan_2k_uk » Tue Jun 21, 2016 11:13 pm
You want wide tyres for 10" rims or they may come away from the bead, especially at low pressure, and leak air or even worse completely deflate.
12.5" is a good width for the rims but it really depends on the type of terrain and driving you plan on using them on.
lukey4x4
Re: Tyres
Post by lukey4x4 » Tue Jun 21, 2016 11:59 pm
cheers dan can you get the 31 with a 12.5 any websites or makes worth lookin at thanks
Re: Tyres
Post by Anton » Wed Jun 22, 2016 8:22 am
I swapped wide track axles onto my 413 which came with the same width axles you have, because the narrow track axles meant my 31's were rubbing on articulation (especially on the back). I have 8J's with 31x10.5's.
Depending on the offset of your 10J's, you might run into the same problem - in fact, the balance of probabilities is that your wheels will go outwards 1" more than mine and inward 1" more than mine, so you're more likely to have the same problem.
It's not by any means sure (you might have 2" more backspacing than me, in which case you'll probably be fine). I'm not the first person to swap SJ413/SJ410 axles for Samurai WT axles.
Re: Tyres
Post by Jordi » Wed Jun 22, 2016 8:44 am
On 33 12.50s you will have tyre rub on 410 axles against the springs and chassis. I get a bit kn my Samurai axles.
A lot of us had tyres from 4x4tyre.co.uk.
As Dan says on 10j rims you need a 12.5 tyre. The rim is actually closer to 12" edge to edge.
lukey4x4
Re: Tyres
Post by lukey4x4 » Wed Jun 22, 2016 12:13 pm
Thanks lads thinking i will just go for some 31s These r the rims i have if i put 31 on them do yas know if it will still rub lyk what anton said , thanks
