No power at ignition.
palo123
Post by palo123 » Sat Nov 26, 2016 12:21 am
Evening all,
I have recently got another soft top c reg sj410 in extremely good condition for almost free! Only problem is when you turn the key absolutely nothing happens. No clicks, sounds or lights on dash but full battery and the ignition barrel is plugged in etc.
Just wondering if there are any fuses i should check or any important cables other than the + and - terminals that i should check?
I haven't actually looked in to it much but just wanted some suggestions on things to check.
Any suggestions appreciated, thanks
Re: No power at ignition.
Post by Darrell » Sat Nov 26, 2016 12:40 am
Sounds like the fuselink my be blown. http://forum.suzukiclubuk.co.uk/vi ... =fuse+link
palo123
Post by palo123 » Sun Nov 27, 2016 12:05 am
Thanks for the reply Darrell.
It wasn't the fuse in the end but it fired up after jiggling some wires and unplugging and plugging in the fuse. I presume it was just dirty contacts and some loose wires.
Thank again
