Too Many Zooks
Too Many Zooks
Post by ScottieJ » Tue Oct 09, 2018 12:47 am
Hi.
I've been having a bit of a break from the inter web but I'm still in the workshop as much as I can be (not enough) and I still own too many zooks.
Let the chopping commence :chainsaw1:
:weld:
:hack:
Re: too many zooks
Post by donkeychomp » Tue Oct 09, 2018 8:45 pm
Is this the buggy project?
Re: too many zooks
Post by ScottieJ » Tue Oct 09, 2018 9:10 pm
No this is just another project :hahaha: Buggy is going to be Lj based and there will be a lot less original sheet metal ;)
Re: too many zooks
Post by ScottieJ » Fri Oct 12, 2018 9:47 pm
Little bit more work done.
Re: too many zooks
Post by donkeychomp » Fri Oct 12, 2018 10:22 pm
Bit of a weld-a-thon. Looks like the usual top work matey.
zook123
Re: too many zooks
Post by zook123 » Sat Oct 13, 2018 11:05 am
*like* :rockin: :rockin: :rockin: :rockin:
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: too many zooks
Post by ScottieJ » Mon Oct 22, 2018 10:06 pm
Done a bit more work on the transmission tunnel etc since these pics but I nearly have all the body welding finished.
Re: too many zooks
Post by ScottieJ » Wed Oct 24, 2018 11:13 pm
Cheers Rankine, It's been a lot of work but should be a nice strong base for a body mounted roll cage. I might add some tube to the box section sills, need to keep those trees away from the doors.
Re: too many zooks
Post by Rankine » Thu Oct 25, 2018 1:27 am
If only could get box section that flat but wider so it was like a solid step. Definetly safe the doors.
timwilks13
SCUK Website Padawan
Re: too many zooks
Post by timwilks13 » Thu Oct 25, 2018 9:20 am
Why would you want a solid step? SJ's aren't that hard to climb in and out of and side steps are just something more to get in the way and catch on stuff.
