weld test today so wish me luck
rockwatt
Recommended Trader
Recommended Trader
Re: weld test today so wish me luck
Post by rockwatt » Thu Nov 25, 2010 9:51 am
parrotveasey81 wrote: im not too sure how they test them but was told that they cut them into sections then fold 1 back on its self antill it breaks,the metal needs to break not the weld,they x ray another bit to see if there are any imperfections and also some thing else that i cant remember :oops:
All our tests are done in house as our QA are loyds certified
We do a pull test to stretch it till it snaps on a 10mm section and record the tons it takes,
Then freeze with co'2 to minus 80deg to do an impact test then a rockwell hardness test on and off the weld to see it hasnt cooled to quickly and gone brittle.
Im not sure what tests are done on alloy but i know its more strict and its much harder to get a good weld with no cavities .
We use stick and tig more than mig as its beter out on plant and much stronger.
Rocklobster gears , refurb cases , dual cases , su manifolds , jimny rocklobster conversions inc speedo drive, t/case heavy duty mounting arms and rock buckets, bespoke fabrications and machining,
Contact me for details.
parrotveasey81
Post by parrotveasey81 » Tue Dec 07, 2010 5:20 am
Post by ScottieJ » Tue Dec 07, 2010 12:11 pm
That's not good matey sorry to hear it! there's always next time! it's a bit strange how nearly everyone failed for the same reasons???
parrotveasey81
Post by parrotveasey81 » Tue Dec 07, 2010 12:52 pm
ScottieJ wrote:That's not good matey sorry to hear it! there's always next time! it's a bit strange how nearly everyone failed for the same reasons???
we are retaking them on the 14th :roll:
that just proves how hard it is to get a good weld
