Hey, so I believe that I need to block all pipes and gubbins in the inlet manifold if I fit a Weber, is that correct? There's an electrical connection or two there as well, at least one with a little bit of kit with the carb name 'Aisin' on it - just do away with them all?
What's the best way to block up any holes in the manifold left behind when pipes are removed? Maybe a silly question but I don't know the answer!
