Coiled turqoise samurai 16v
d_r_1989
Re: Coiled turqoise samurai 16v
Post by d_r_1989 » Sun May 04, 2025 10:59 pm
So after today's test drive, iv realised the speedo is quite away out so may need to swap the vitara speedo head for a Japanese sj head. The speedo does read but it's abit slower than actual. Going to do some research and see if it matters or not
Post by Rankine » Mon May 05, 2025 7:49 pm
Looking and sounding lovely. Is it the calibration between that and the large tires to?
Me and a few of my mates are heading to drumclog on the 18th if you fancy it?
Post by ScottieJ » Mon May 05, 2025 10:29 pm
You can calibrate the speedos quite easily if I remember correctly. I’ll try to find the thread with it in.
How do you like the 16v vs the old 8v?
d_r_1989
Post by d_r_1989 » Mon May 05, 2025 11:18 pm
Thanks rankine, as much as id like to I don't think I'll get chsnce, though the green one is raring to get out!
I haven't driven it enough to get a proper feel scottie, iv only driven round the block. I can say though it feels alot more responsive and torquey.
Hopefully the speedo will recalibrate quite easy.
I think the next thing to do would be jimny 4.3 diffs and a rocklobster to make better use of the 16v
Whilst it's still in garage iv pulled rear bumper off to give it a clean up. Getting a right overhaul is old girl, suppose it's only fair, been on road 4 years now!
Post by Rankine » Tue May 06, 2025 8:41 am
All good man always the next one! Best part of these cars they keep us busy with the follow up work 😂
Post by ScottieJ » Tue May 06, 2025 10:25 am
https://www.suzukiclubuk.co.uk/how-to-t ... ate-speedo
It was in the how to section, pictures aren’t the best but the little lever is quite obvious once you have it apart. It is going to be a bit of trial and error to get it right though.
It might be slightly different on the jap/vit style speedo but I do recall seeing a little calibration lever
d_r_1989
Post by d_r_1989 » Wed May 07, 2025 6:37 pm
Definitely keeping me busy! I'm hoping I'm back home at a decent time Friday and can refit rear bumper and lights and then mot Saturday
I'll pull it apart this weekend and give that a try scottie thanks for that. It could well be iv messed it up while I had it in bits resetting mileage.
d_r_1989
Post by d_r_1989 » Sat May 10, 2025 9:05 pm
Got the seat mounts painted
Post by Rankine » Sun May 11, 2025 8:27 am
Look a good fit in there man.
d_r_1989
Post by d_r_1989 » Fri May 16, 2025 1:21 pm
Ye they're such an upgrade to them original seats!
So it's passed it's mot and developed a leak on the rear caliper on the way home, new caliper for £38 and problem sorted.
A couple pics of the caliper setup for anyone that's interested, mx5 calipers are really easy to work with.
Now the rubber mats to cut and we are done for a while 🤞
