parrots trak
Re: parrots trak
... if you do that still have the stinger sticking out of it...
I think a downwards folding tailgate would be great as well... you would have to have some decent attachments at the top for when it's closed...
otherwise the stinger wouldn't be too useful
- Can I have a tow
Re: parrots trak
Edweird wrote:I like that one too. I'd say have it hinge down like a range rover lower tail gate. I think if it were me I'd also weld some sheet to the pipework rather than leave it as a bare frame of a tailgate.
yea i think thats the way to go plus i could sit on it when its down but i think i will go for a half tail gate
- Can I have a tow
Re: parrots trak
well before i went ahead with a half tube rear tail gate i thought i would cut out the old tail gate,i must say i think i will go for a half tube tail gate with sheet between the tubes to stop things falling out if/when i put things in the back.
i also drilled the holes in the diff guards for the filler plug
not too sure if the fitted the new tyre right??not sure if the bead is seated right
Re: parrots trak
lookin good i do like the new tyers
go fo a half tailgate as in your last pic and bottom hinge
- Can I have a tow
Re: parrots trak
ROBBIE wrote:lookin good i do like the new tyersgo fo a half tailgate as in your last pic and bottom hinge
thanks,yea i think i will but for once im not going to rush into making one as i need to put any spare cash towards more tyres
- Can I have a tow
Re: parrots trak
FOURTRAK POWER
picked up the push rods today and fitted them,got it running but it was miss fireing and rattled bad when reved,miss fire was a rocker too tight,the rattle was the crank was 1 tooth out
Re: parrots trak
- Can I have a tow
Re: parrots trak
ScottieJ wrote:nice work matey! Bet your glad its sorted
so when do you think the other 2 37s will be coming?
will order them tomorrow so maybe saturday or monday i should get them
- Can I have a tow
Re: parrots trak
had the tyres fitted today so i took the dog for a walk so i could flex the truck up to see if they catch on the rear,they clear the driverside but catch on the passenger side(the axle is pulled to that side with the panard rod,must fit my adjustable one),other than that the rear is all good
loaded ready to go get them fitted
all fitted and on the way home
new wheel is black,my old ones are not so will need to paint them soon
