Henry
- Suzuki Guru
Post
by Henry » Sat Jun 11, 2011 2:40 pm
twiss wrote:See I reckon it would go a bit faster without the rocklobster... as I believe the ratio for 2H is still different to that of a samurai t-box
Think the rocklobster drops high box by 70%
I had 57 out of mine flat out down a 2 mile dead straight
Saying that i had about 7psi in my tires..
Henry
- Suzuki Guru
Post
by Henry » Sat Jun 11, 2011 2:41 pm
Henry wrote:twiss wrote:See I reckon it would go a bit faster without the rocklobster... as I believe the ratio for 2H is still different to that of a samurai t-box
Think the rocklobster drops high box by 20%
Post
by ROBBIE » Sat Jun 11, 2011 5:49 pm
the old beast can do over 70, But the noise is horrendous
cherry bomb middle box cherry bomb back box insa special tracks,over 50 you cant even hear the stereo
- The Boss
Post
by ScottieJ » Sat Jun 11, 2011 5:55 pm
what size tyres do you run russ?
if no more than 31s i'd say go back to spua but with rear springs up front and a small shackle lift in the rear to compensate for the height difference. (did i just say that
lift shackles
yeah i did, on the rear i think little bit of extra length wont hurt too much!)
Post
by twiss » Sat Jun 11, 2011 8:17 pm
I've still got shackles on the back of mine still. Its not really a problem because by the time they hit the floor you're normally well on your way through the obstacle
Post
by turbo-tom » Sat Jun 11, 2011 9:22 pm
or get calmini suspension but thats silly money , rock hard on the road (so thats the stable issue sorted out
) , and run grizzlys 31inch , and drive with ear defenders on
Tom
Ford Fiesta ST
Post
by ROBBIE » Sat Jun 11, 2011 9:30 pm
twiss wrote:I've still got shackles on the back of mine still. Its not really a problem because by the time they hit the floor you're normally well on your way through the obstacle
so have i and ive got rhino rays reversal kit up front the same as you russ
Russ24
- Can I have a tow
Post
by Russ24 » Mon Jun 13, 2011 11:26 am
i run 215 15 diamond backs.
no good on the road.
with SPOA....
got a standard set of steel rims with standard tyres.. off a vitara... but also got a set of chrome-ish rims with 245 road tyres... look like bubble tyres.
revert back to SPUA.... i dont want to upgrade the size of the engine as i have recently as in the beginning of the year forked out for a moded manifold and an SU carb.
anyways i wouldnt put a petrol in again.. i would go with diesel.
looks like im stuck with the 45mph for awhile.
- The Boss
Post
by ScottieJ » Mon Jun 13, 2011 12:06 pm
so your tyres are around 28" tall then, in that case you don't really need any lift at all and I dont understand why you can only do 45mph? my 970cc lump with a 410 tbox & 30" tyres would hit 70mph easy enough
keep the 413 tbox as it is higher geared than a 410/lobster box(so lower revs at a higher speed) and get your air/fuel ratio and timing checked.
Something really isn't right if you can only do 45mph
Post
by twiss » Mon Jun 13, 2011 12:13 pm
Russ, bring your zooki down to mine and we'll check in with the colourtune and the EGA
