Going Topless !
Going Topless !
l took advantage of the hot weather on Sunday to take the hood off and go for a spin,not literally l have to say. The only problem is the buzzing headlamp relay which l will look at next weekend. Here are some pictures l took on Sunday.
Tramp mentioned seeing some clip on covers for the SJ some time ago,but said they were very rare,well after a lot of searching,l found a supplier in America and ordered three items which came today. These are: Bikini Top(ha ha)over the cab,Windjammer,()vertical window panel behind front seats and Duster(tonneau)which clips over the rear body sides. Now the tonneau is quite a good fit but the other two need the Sport Bars as on the Samurai,to strap around.Are these available here anywhere ? The windjammer isn't wide enough to fit without the bar and would need extending to reach the body hoop. l may end up selling them on if it is not easy or possible to make use of them.
- astons at donington 2011 056.JPG (477.17 KiB) Viewed 56713 times
- astons at donington 2011 060.JPG (489.12 KiB) Viewed 56713 times
- astons at donington 2011 058.JPG (489.26 KiB) Viewed 56713 times
- astons at donington 2011 061.JPG (483.74 KiB) Viewed 56713 times
Re: Going Topless !
I still just can't believe how tidy your sj is!
- Tramp
Re: Going Topless !
what an awesome SJ! I love ti when the weather is nice to take the roof off and Sj's looks so much better topless! Can we have a picture of the tonneau fitted? I have been toying with the idea of a truck cab for a while but dislike the idea of something permanent a soft top truck cab would be just what the doctors ordered!
The sports bar... Is it just the extra roll over cage that came as standard on some (other than England) market SJ's? basically just a U shape tube with some supports that sits behind the box section roll over hoop (where your curtsey light is fitted) which bolts to the floor. I know you will have heard this before but they occasionally appear on ebay
Re: Going Topless !
Sod the usual topless pics, ive just had an accident
Lovely truck, but why does it have a sammy bonnet?
Re: Going Topless !
Hi Hugh and Tramp, the fitting instructions called the roll hoop a 'sports bar' shown on a Samurai which is the only model they cater for.l would say it is the standard hoop fitted for the American market and others but not for the UK Altogether,with shipping and import taxes,they have cost me £238 ! take a look at http://www.tops4less.com" onclick="window.open(this.href);return false; for more details. The tonneau is a good fit but they say you need 70 degrees when fitting to stretch the fabric and it's pouring with rain today. The next hot day we have l will fit it and take some pictures. The cab(bikini) top is on now but l am short of the roll hoop to tie it to,same with the Windjammer,does your SJ have the bar/hoop on it hugh ?
Apart from being garaged most of its life,it has also had just two caring owners as well. lf l didn't have so many other projects,l would probably pull it apart to repaint the running gear just to mint it up,but for now waxspraying and brushing will do to keep the demon rust at bay. lncidently,l recommend the Comma Wax Spray aerosols,which are hand to use and don't need warming up like Waxoyl does l will be picking up half a dozen cans in the morning.Watch out for the silicone though if you are painting!
Re: Going Topless !
This bar ??
http://forum.difflock.com/viewtopic.php ... 604c356abd" onclick="window.open(this.href);return false;
- roll.JPG (89.63 KiB) Viewed 56636 times
- Tramp
Re: Going Topless !
Cheers I'm looking forward to the pics, If you havn't got the roll bar it may be worth cutting up a soft top of your own to get the bikini top and back, Or equally you could find someone with a pipe bender and see if they are willing to make you one, Or even going to monsoon and buying the bikini top that would fit with out the sports bar,
Yes Darrell I think that is the one, on the fujimi models they come with the bar, so I imagine it was standard for the Japanese market too
In the Suzuki Gold portfolio it makes a reference to this bar (in an australian article) and suggests that it was an optional extra
Re: Going Topless !
^^^^ this is exactly what they are calling the sports bar in the US market, it was available in the UK as an optional extra as I know loads of SJs that have had them fitted. TBH I think it was an optional extra in most countries and not a standard item.Darrell wrote:This bar ??
we just call them the factory roll bar over here.
they do pop up on ebay every so often
the purple bit of this cage is just a factory roll bar
Re: Going Topless !
stole this of differs
- 15713_suzuki_rollbar_1.jpg (34.85 KiB) Viewed 56614 times
Re: Going Topless and Roll Bars
Thanks for the idea Tramp. l think a modified hood,or a new one using the guide slots on each side of the original body hoop to create the Windjammer would help to keep the weather out,an alternative would be a nice chrome plated original roll bar !
