New member - Own LWB SJ413
Rjmaas512
Re: New member - Own LWB SJ413
Post by Rjmaas512 » Tue Jul 19, 2011 6:04 pm
Photographs as promised. I have found out they are hella headlights. Found some that sold on ebay a day ago... GRRRR :argh:. It's also raining now so putting a hold on finishing the welding :argh: :argh:.
If anyone knows where I can get hold of some new ones that would be great.
I am thinking of putting the new headlight in the oven to separate the glass from the headlight and join it back together with some silicone stuff. Seen a guide on how to do this on the internet, so might give that a try.
Thanks,
Rob
Headlight 1 (Small).jpg (87.42 KiB) Viewed 9225 times
Headlight 2 (Small).jpg (82.98 KiB) Viewed 9225 times
Headlight 3 (Small).jpg (109.86 KiB) Viewed 9225 times
Headlight 4 (Small).jpg (95.9 KiB) Viewed 9225 times
Rjmaas512
Post by Rjmaas512 » Tue Jul 19, 2011 6:09 pm
Pictures from todays work - Productive day but waiting for the :thefinger: rain to stop.
Friend of mine has some how has the patience to weld the front wing back together!
Front Wing Arch (2).jpg (344.19 KiB) Viewed 9203 times
Wheel Arch (2) (Small).jpg (48.1 KiB) Viewed 9203 times
Rear New Lights (Small).jpg (58.56 KiB) Viewed 9203 times
Wiring Rear lights (Small).jpg (119.41 KiB) Viewed 9203 times
Rear Passanger Welded (Small).jpg (77.27 KiB) Viewed 9203 times
bigben
Post by bigben » Tue Jul 19, 2011 8:25 pm
looking good you dont need anymore silicane just pop it back in the oven for 5 and the glue will bond itself back as it cools matey
Rjmaas512
Post by Rjmaas512 » Tue Jul 19, 2011 10:20 pm
bigben wrote:looking good you dont need anymore silicane just pop it back in the oven for 5 and the glue will bond itself back as it cools matey
Perfect Thanks, will make use of this information
albertross74
Post by albertross74 » Wed Jul 20, 2011 1:04 am
nice work, I want an LWB so bad!
Rjmaas512
Post by Rjmaas512 » Wed Jul 20, 2011 6:17 pm
Update - MOT
Well just booked the MOT for Friday 15:00, when it will inevitably fail after all the hard work that has been put into the darn thing.
Insurance will be purchased later on tonight to start on Friday morning. Then tax when it well... eventually passes. Expensive few days for me.
Head gasket has arrived so that's a job to start on Sunday, get the head Skimmed Monday and re-fit Tuesday before going on holiday on Wednesday.
Timing belt kit is ordered.
Next thing on the list is CB I think.
Rjmaas512
Post by Rjmaas512 » Wed Jul 20, 2011 9:08 pm
One successfully separated piece of glass from the headlight. Stick it in the oven on high for 20 mins comes off a treat :)
Headlight (Glass Seperated).jpg (67 KiB) Viewed 9173 times
albertross74
Post by albertross74 » Thu Jul 21, 2011 3:37 pm
good luck with the mot mate
Rjmaas512
Post by Rjmaas512 » Sat Jul 23, 2011 4:53 pm
Well it failed.
Basically on the rear brake hose. Noticed it just before the MOT so thought I might as well try. 14 days free re-test so take that in after it is replaced and I am sorted.
They were really picky on one weld. patch was about half a meter so did not fully weld the end of it as it was more than 30cm away from the seat belt mount. So need to finish that weld (5 min job) and all is sorted.
On holiday as of next week so will order parts ready to have it on the road Monday 1st of August.
List of advisory's... Not as bad as I was expecting. Need to do the brake lines them selves at some point as they are in need, but will do that for next MOT. Front tyre and rear cross member (which i thought did not apply as it was not load bearing).
So all in all better than I was expecting.
For now just wondering which one of these to get...
http://www.amazon.co.uk/Goodridge-Braid ... 711&sr=1-2" onclick="window.open(this.href);return false;
http://www.amazon.co.uk/Goodridge-Braid ... 736&sr=1-1" onclick="window.open(this.href);return false;
Only reason for using amazon is I get 10% discount using my NUS Extra card (making use of being a student).
Looking through the manual for part number at the moment.
Thanks,
Rob
albertross74
Post by albertross74 » Sun Jul 24, 2011 10:13 am
unlucky, still at least you know it'll get through next time.
as for brake hoses check out the ones on LLama http://www.llama4x4.co.uk/" onclick="window.open(this.href);return false;
