Pretty in pink, work so far
pompeybloke
Post by pompeybloke » Tue Sep 06, 2011 10:33 pm
I been busy in her first year unfortunately it's all been mechanical repairs of some sort or other
the list includes
New cv joint last Christmas then the bottom end of the engine gave out and had to put a replacement in that i found on the bay for £125 but before fitting it I replaced the head gasket cam belt and tensioner and a new clutch all easy jobs with the engine out.
Last week i started tidying up underneath all around the rear end cleaned all loose rust away then primed with some red oxide followed by couple coats industrial black paint.
Will be tackling front end next time we got some dry weather then finish off underneath with good coat under seal.
I included few pics as i know how much you all love you pictures :D
Finished
Finished
Primed
Primed
Before
Before
Before
Before
