Missfire? Plugs and Leads
- Edweird
Hey up lads and lasses.
Firstly, I'm having another spluttering problem, but this is more intermittant, is worse in the damp and doesn't occur beyond what I reckon to be about 2000rpm. I think it's ignition related. Any ideas for diagnosis? I have a multimeter.
I get a staff discount at Halfords, along with trade discount on parts, so I can get a set of NGK plugs for £8.50. Is that a reasonable price? I get the same discount on leads, which come to about £18 for all 5 leads.
They also do these special Bosch 'super 4' plugs. Plugs with 4 electrodes. The automotive fitter, Paul, at work rates them pretty well and he's a trustworthy chap. I can see them being a pain to gap but otherwise okay, but they cost an extra £4 on top of the NGK's after discount. Are they worth it?
Cheers, Ed.
Cheers, Ed.
Re: Missfire? Plugs and Leads
probably not. Get some spray that you put on to "aid starting in damp conditions" Carnt see such modern plugs doing much to the 1L sj engine!
Mine cuts out in any type of water or rain/splash up. Plan is to get the "fine mist" setting on the hose pipe at night, on tick over spray over engine bay and look for arcs!
For what it's worth get a new set of plugs and leads on. Might as well have a new dizzy and rotor arm too. Their cheap parts and will rule out a lot of potential problems. Just my opinion anyway
Pointless chasing around after other running faults of your unsure about the condition of the basic ignition components. After that you can start looking at carb settings, compression testing etc
Is your hot air feed from the exhaust manifold fitted? If so have you opened up hot air intake on the airbox? Could be carb freeze if not now that it is getting cold.
I've tried the super 4 plugs and the Y split plugs. I think there is a small difference between them and regular plugs but I cant really tell the difference between the two
I normally find that sputtering ends up being water in my distributor, or knackered leads
on the subject of this I have just tried something I have been meaning to do for a while.
just did a test using an 11kv glue filled shrink terminal boot at work to see if it would shrink down to the size of a distributor and it does.
going to use it to seal over my distributor cap/housing joint and got some of the same stuff but smaller to seal the HT leads to the plugs and the cap.
Should be totally water proof.
just need to make something up to clamp the cap down so I can loose the old cap clips
will let you all know how it goes
Dan
Dan
- 20111019_001.jpg (502.97 KiB) Viewed 6723 times
- 20111019_002.jpg (498.25 KiB) Viewed 6723 times
- 20111019_003.jpg (472.49 KiB) Viewed 6723 times
- Edweird
Thanks for the rapid responses folks.
My step-dad suggested that spray stuff. Where's likely to have some, 'cause I'll try that before buying plugs and leads if it's cheap? I had a feeling that would be the case with the fancy plugs too.Henry wrote:Get some spray that you put on to "aid starting in damp conditions". Can't see such modern plugs doing much to the 1L sj engine!
It had a new dizzy cap, rotor, condenser and points not too long ago, but I'll keep that in mind.Christoff wrote:For what it's worth get a new set of plugs and leads on. Might as well have a new dizzy and rotor arm too. Their cheap parts and will rule out a lot of potential problems.
Yep, already did that 'cause the weather's getting colder.ScottieJ wrote:Is your hot air feed from the exhaust manifold fitted? If so have you opened up hot air intake on the airbox?
Similar to what Henry said then. They're better, but not by a lot. The leads ARE the originals so it could be that.twiss wrote:I've tried the super 4 plugs and the Y split plugs. I think there is a small difference between them and regular plugs but I cant really tell the difference between the two
What's wrong with a rubber glove and cable ties?dan_2k_uk wrote:on the subject of this I have just tried something I have been meaning to do for a while.
Dan
Mine was sputtering intermittently, then I went through a big puddle and it cut out...
Big puddle =
Went to take off the main lead from the coil and the end of it came off
Big puddle =
If they are the orig leads GET EM CHANGED!
I had to ask Ed
its an easy thing to forget
Have you checked the gap on the points? Also sometimes cheap condensors don't last that long, can you remember what brand you got?
Checked the coil resistance?
And yeah as Henry said its always worth fitting new leads if you haven't already.
