wiring in ford altenater
st3f4n
Re: wiring in ford altenater
Post by st3f4n » Sun Nov 13, 2011 1:24 pm
I had a look here and its says something to do with the alt:
http://forum.difflock.com/viewtopic.php ... 2f56f799a9" onclick="window.open(this.href);return false;
Thanks again
Edit i am using an su now so if its not alt related does it just want taping up and not using.?
Post by Darrell » Sun Nov 13, 2011 3:53 pm
Yes that black/white is a switched live and goes to the standard alternator (so not needed now), the ignition coil and the fuel solenoid/shut off valve (not needed with an SU) . Yes just insulating the ends with suitable tape will do. I took some pics of the engine bay and piping, I will resize/sort these out later today if you need them to suss out the cooling.
st3f4n
Post by st3f4n » Sun Nov 13, 2011 4:53 pm
Fantastic mate, Thanks for clearing that up! Much appreciated!!
Think iv sorted the cooling but if its not to much hassle to you then it wouldn't hurt for me to check ive done it right.
Progressive day and providing getting my inlet mani down to Rockwatt tomorrow and wiring in some sidelights and tidying the above wiring, could be all done and ready for a mot this week :D
Thanks again!!
Post by Darrell » Sun Nov 13, 2011 5:25 pm
Decided not to bother with the photos as mine is a 413 and the vit is a little different. That and the fact your fitting an SU which does away with about a hundred soddin little hoses including ones that heated sections on the original carb. So thought I'd just post up this......
Post by twiss » Mon Nov 14, 2011 9:23 am
Looks like an interesting alternator... I'd be surprised if you couldn't "mod" the square SJ connector to fit in it ;)
st3f4n
Post by st3f4n » Mon Nov 14, 2011 11:03 am
Thanks mate, looks like I figured it out correctly, I'm presuming the vac for the brake servo is the pipe below the carb intake
st3f4n
Post by st3f4n » Mon Nov 14, 2011 11:05 am
twiss wrote:Looks like an interesting alternator... I'd be surprised if you couldn't "mod" the square SJ connector to fit in it ;)
That would of been a preferred method but the original connectors not there lol
Post by twiss » Mon Nov 14, 2011 11:38 am
Spade connectors superglued together then? ;)
Mine's the same, bough a vit engine and it has a round plug, had to chop off the regular one
st3f4n
Post by st3f4n » Mon Nov 14, 2011 1:27 pm
Got two of the larger connectors from work today so should be ok now. Its come on this weekend alot, cant wait to get it MOT'd
Post by Darrell » Mon Nov 14, 2011 7:07 pm
Sure is :thumbup:
