Gear shift lever locating bolt
richone, not
Post by richone, not » Wed May 30, 2012 12:57 pm
I only seem to come here when I want something, which make me feel a bit ignorunt, however I am desperate, again.
I tried searching the forum for "gear shift lever locating bolt" but maybe i am doing it wrong as i know that these bolts snapping is quite common.
So, does anyone know where i can get a gear shift lever locating bolt, for a 1993 SJ413 SAMURI SPORT, I tried Unipart.
Thanks, again, Rich.
ianedwards
Re: Gear shift lever locating bolt
Post by ianedwards » Wed May 30, 2012 1:22 pm
i bought a kit from mountain goat performance, bolt + bush for gearbox and bush for the transfer box - recomended.
but i also think they sell the bolts seperatly. they do
http://www.mountaingoatperformance.eu/d ... s.html?p=2
Ian
Ian. :)
Post by dan_2k_uk » Wed May 30, 2012 4:10 pm
I just got a stainless M8 bolt and cut ot to the correct length.
Stuck it in a drill and twizzled it against an angle grinder (Redneck lathe) to get the correct profile on the end.
Then just gave it another spin with some wet n dry pinched over the end to remove any roughness.
Sorted :thumbup:
richone, not
Post by richone, not » Wed May 30, 2012 4:58 pm
ianedwards wrote:i bought a kit from mountain goat performance, bolt + bush for gearbox and bush for the transfer box - recomended.
Ian
Thanks Ian, apparently it is for a 86-89, mine is a 93, so naturally i ordered one any way.
just the bolt £2.60
richone, not
Post by richone, not » Wed May 30, 2012 5:07 pm
dan_2k_uk wrote:I just got a stainless M8 bolt and cut ot to the correct length.
Sorted :thumbup:
I thought that, but i hav'nt even got a redneck lathe, I was thinking maybe a file, thanks, rich
ianedwards
Post by ianedwards » Wed May 30, 2012 10:31 pm
sorry didnt notice that. i dont know if they are different, or if they are different at all. lol
did they ever change the design later on? might be interesting to know.
Ian
Ian. :)
richone, not
Post by richone, not » Sun Jul 15, 2012 4:37 pm
Hi, that took a while, but the 1989 fitted the 1993, cheers Rich.
