Clutch or gearbox problem ??
Hi im getting a clutch fitted in my vitara thursday as its quiet high but from today i noticed it so hard to get in gears is it caused by the clutch or am i looking at a gearbox problem didnt want to get clutch fitted then have to pay to get gearbox taken out again after how can i check both for the cure cheers guys
Re: Clutch or gearbox problem ??
Yes hard gear selection can be caused by the clutch, you could crawling underneath and try adjusting the cable to take any slack out to see if that helps for the time being.
As he said up there.
I'm just agreeing as i can't think of another possible answer right now.
