grill
- dazerede
Re: grill
U mean this to this
- 4755_IMG_2403_copy_600_x_400_1.jpg (68.7 KiB) Viewed 5280 times
- file-5.jpeg (1.51 MiB) Viewed 5280 times
4” calmini lift kit
4” calmini lift kit
Re: grill
Yes you can change a 410 steel grill to a 413/samurai plastic grill, but you will have to chop it out and make safe the Sharp edges, it's the same width if that's what you mean. I chopped mine out to fit a plastic grill to fit a radiator in
Re: grill
No cutting needed, the front panel section will unbolt 'if' you can get the screws undone, then you just need to bolt in the front panel off a samurai/413 or you can just swap over the whole front section, wings and all bit then you'll need to drill out the spot welds on the arch mounts and swap those over.
Why would you want to anyway? The 410 metal grill looks so much better than a later plastic grill in my opinion
hence why I'm fitting a 410 grill on my LWB.
