If i...
If i...
Post by Jordi » Mon Apr 08, 2013 9:29 pm
So, got me rocklobster. And all the gear to do a rear disc conversion.
Just wondering prior to doing it all, can i fit the rocklobster with the transmission brake minus all the inside bits and still run it?
Then when i do the disc conversion just pop the drum off and put the shoes and bits n pieces in it?
Re: If i...
Post by ScottieJ » Mon Apr 08, 2013 9:39 pm
Yes :thumbup:
Re: If i...
Post by Jordi » Mon Apr 08, 2013 9:42 pm
Sound. Cheers Scott.
I'll bring it all down with me, unless i get a spare half hour before hand.
Re: If i...
Post by dan_2k_uk » Mon Apr 08, 2013 11:48 pm
I would just leave all the shoes etc in it and either tie the cable up out of the way for now or start using it as your handbrake immediatly and remove the old cables to the rears.
Re: If i...
Post by Jordi » Mon Apr 08, 2013 11:55 pm
Haven't got new cable and shoes yet Dan. If i can get them by the weekend i might do that.
Re: If i...
Post by dan_2k_uk » Tue Apr 09, 2013 8:13 am
Ah I understand. In which case just leave it on as Scottie said. The drum is basically just an extended flange anyway.
