parrots vit project
- Can I have a tow
parrots vit project
the plan is to take my swb vit cut the front and rear off,tray back and tube front then mount it on a home made chassis with my lux axles with 37" tyres and my vit engine and gear box.
work has already started on my chassis,im using 1oommx50mmx3mm box and lots of 6mm plate.
- 051.jpg (167.76 KiB) Viewed 15472 times
- 052.jpg (139.41 KiB) Viewed 15477 times
- 053.jpg (106.36 KiB) Viewed 15479 times
- Can I have a tow
Re: parrots vit project
cut and bent some 6mm plate today for the spring mounts and cut some 60mmx40mmx3 for the body/cage mounts plus some 100mmx50mmx3.
hoping to get spring mounts/body mounts and gear box cross member fitted this week end and possibly fit the engine and box ready to make some engine mounts,will post again Monday night
- 049.jpg (74.32 KiB) Viewed 15416 times
- 050.jpg (63.25 KiB) Viewed 15420 times
- 051.jpg (88.48 KiB) Viewed 15421 times
master fabricator at work! lookin good already
- Can I have a tow
thanks,the hard part is to come,cutting the body up and keeping the quality that ive started
- Can I have a tow
body/cage mounts and spring mounts fitted just need to add lots of bracing
- 074.jpg (108.51 KiB) Viewed 15332 times
- 077.jpg (130.73 KiB) Viewed 15334 times
- 079.jpg (116.82 KiB) Viewed 15338 times
looking good there fella,, nice welding,,
andy
andy
eeeeerrrrr thats dangorous that is not having a safety gaurd on mr angry, he bites if your not careful you know
keep it up matey and you know i'm just up the road if you need help lifting anything else! damn those hi lux axles were heavy
- Can I have a tow
mr angry only bites if he does not like you(he must hate me he bite twice)scottiej410 wrote:eeeeerrrrr thats dangorous that is not having a safety gaurd on mr angry, he bites if your not careful you know![]()
yea those axles are heavy and we will have the fun of them again in a couple of weeks
placed the axles under the chassis and taken the engine out of the vit,should get the gear box out tomorrow and fit them at the week end
- 072.jpg (94.84 KiB) Viewed 15248 times
- 075.jpg (90.02 KiB) Viewed 15251 times
- Can I have a tow
fitted the gearbox today but by the looks of it the engine will be to close to the axle so i may half to do a 1 link on the front
- 072.jpg (97.91 KiB) Viewed 15221 times
- 073.jpg (86.1 KiB) Viewed 15220 times
- 074.jpg (81.92 KiB) Viewed 15220 times
- Can I have a tow
fitted my engine mounts today
- 097.jpg (85.56 KiB) Viewed 15181 times
