my little project
- stevepsj413
my little project
Just bought half an sj, the other half was victim of the rust demon, thought it was time i learnt to weld! A few pics of my progress so far, not the neatest of jobs but it should be strong.
- gettin there but still not finished yet, 5kg of welding wire n a 9kg argon gas bottle later
- DSC_0091.jpg (342.27 KiB) Viewed 7112 times
- DSC_0090.jpg (305.86 KiB) Viewed 7112 times
- DSC_0088.jpg (428.1 KiB) Viewed 7112 times
- DSC_0087.jpg (380.73 KiB) Viewed 7112 times
- 1.2mm thick galv steel
- DSC_0086.jpg (418.69 KiB) Viewed 7112 times
- DSC_0079.jpg (420.63 KiB) Viewed 7112 times
- DSC_0077.jpg (604.76 KiB) Viewed 7112 times
- in with the new
- DSC_0078.jpg (559.46 KiB) Viewed 7112 times
- out with the old
- DSC_0069.jpg (483.87 KiB) Viewed 7112 times
- cut the old rusty bits out and braced the sides
- DSC_0056.jpg (530.45 KiB) Viewed 7112 times
- DSC_0043.jpg (523.81 KiB) Viewed 7112 times
- can you see wots missin
- DSC_0042.jpg (555.38 KiB) Viewed 7112 times
- not so from the back
- sj.JPG (89.67 KiB) Viewed 7112 times
- doesnt look bad from the front
- sj1.JPG (81.91 KiB) Viewed 7112 times
- donkeychomp
Re: my little project
Welcome! And some very nice work there, glad to see another SJ saved from the scrap heap. If you get stuck you are in the right place, just ask
- stevepsj413
its already got shackle lift n swivel hubs, bigger wheels and shockers off a ford maverick on it, just cant wait to get it mot'd and get off road n show them landys how its done! but got big plans for it, snorkel, roll cage, runs like a washin machine full of bricks at moment but im sure i can sort that, bit of wd40 and an oily rag maybe
nice work, looks like you learnt to weld pretty well. are you going to put any bracing under that rear floor to prevent sagging and vibrations?
Welcome to SCUK.
All i can say is i hate your fab work, its soooo nice and tidy. Damn you.
Lools like you've done a good job boss, nice to see another rotter revived.
Hi and welcome.
Looks tidy. As said that floor will probably rattle and vibrate a lot without bracing. Unless its sat straight on the rubbers on the chassis but even then it will vibrate.
