On road Gear Ratios
On road Gear Ratios
Does anyone on here have a 1.6 mounted to a 413 box and 410 transfer box?
im curious of how many revs the engine does in 5th gear doing 50mph and 60mph...
i drive my zuk to and from wales alot so the shortest journey is about 50 miles and up to about 140 miles...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Re: Rear disc conversion is it worth it? Thoughts on set ups
1.3 box, 1.6 engine, rock lobster on 33s. No idea what revs it does at what speed as the speedo calibration is a million miles out. Followed my dad to the off road centre. He said he was doing 65. My Zuk read 50.Jay18 wrote:i will have to have a look at my calipers then, one of my drums were bunding as it was very hot after bringing it home from the storage, but it doesnt seem to get so hot now so i would say its fixed itself, just need to check the calipers arent sticking, should be okay then...
want to get by 1.6 conversion done, cant wait to do it lol
while mentioning that, does anyone on here have a 1.6 mounted to a 413 box and 410 transfer box?
sounds like a good plan anton..
jordi; my speedo is out by 2 mph according to my satnav lol so when the zuk says 40mph the satnav says 38mph
does the speedo read from the transfer box? i know the speedo cable goes that way somewhere lol
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
I've always found that satnav's tend to give a reading about 2-3mph lower than the speedo on my cars. Talking about unmolested road cars here, like both of my Yaris's, not the SJ. That's with a Tomtom, though, I haven't tried using one of these GPS based speedo apps you can get for your phone.
So bear in mind that your speedo might be bang on, and the satnav reading slightly slow - or that my road cars may have all read slightly high!
i have noticed that satnavs tend to read 2pmh below what the vehicle says..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
I think on new vehicles they do it on purpose, makes you drive a bit slower, and when the speedo cable inevitably stretches it will be less out than if they had started it at the correct speed
how does that work? it'll still be spinning at the same speed?twiss wrote: when the speedo cable inevitably stretches it will be less out than if they had started it at the correct speed
All vehicles over read. Its to cover the maunfacturers arses. GPS wil be most accurate.
Yes Jay the speedo reads from the output of the transfer box.
I have a 1.6 with 1.3 box and 410 transfer box. On 31s it has a top speed of 71mph and even then I wouldn't say it was screaming its tits off. Its more wind resistance and tyre drag than the rev limiter that limits the top speed.
- littlesammy
Jordi wrote:1.3 box, 1.6 engine, rock lobster on 33s. No idea what revs it does at what speed as the speedo calibration is a million miles out. Followed my dad to the off road centre. He said he was doing 65. My Zuk read 50.Jay18 wrote:i will have to have a look at my calipers then, one of my drums were bunding as it was very hot after bringing it home from the storage, but it doesnt seem to get so hot now so i would say its fixed itself, just need to check the calipers arent sticking, should be okay then...
I got pretty much the same spec as you jordi and my speedo won't read over 55 even down hill.,lol.!
and my speedo is way out too mate. According to mine i dont get over 55 flat out down hill.,lol.!
I got pretty much same spec as you
87 Samurai with added spice !
To work out rpm at the vehicle speed use the ratios found in this thread and Tim pinks spreadsheet download. http://forum.suzukiclubuk.co.uk/vi ... =12&t=2947
