su accelerator bracket help
- timwilks13
- SCUK Website Padawan
I'm using a hif44 from a pair but neither pair has any sort of fixing for an accelerator cable, had a look to see if I could bodge on something from my aisian carb but to no avail. its a hard problem to explain but i need something like on the old aisian carb where you have a bit of bent channel that the cable sits in...sorry if I'm not explaining this very well, but here is the su without the bit I could do with.
- IMAG01091421348049.jpg (1.36 MiB) Viewed 7474 times
- timwilks13
Re: su accelerator bracket help
thanks kibris but its where the throttle attaches to the butterfly that I'm missing, ill Photoshop something together tonight to explain.
- timwilks13
this is what I'm after, can anyone confirm it will go on my hif44?
This bit??
- 1345038302_428866270_1-Fotos-de--carburador-SU-HIF-44-Austin-Mini-Metro-ou-outro.jpg (52.18 KiB) Viewed 7448 times
- timwilks13
http://www.ebay.co.uk/itm/SU-HIF44-1-Ca ... 1055739366
- timwilks13
yea that bit, didn't see your post till I posted that Darrell sorry!
Its worth checking out sucarb.co.uk
Maybe give them a call and find out which one is best
http://sucarb.co.uk/levers-throttle-stops.html
As Twiss said give them a ring. I've found this but don't know it its correct. Some SU's have a little tag with a number on for identification.
http://sucarb.co.uk/cam-lever-19084.html
- timwilks13
thank for your help guys, still havent found the exact bit im looking for, but all the above has been brilliantly helpful!! and i will continue to search, but in the mean time i have take the throttle arm off my old aisian carb, cut off the extra stopper arm bits and just bolted it on the the current SU throttle. Bit of a bodge but seems to work, ill put up a picture later if and when i remember to take one!
