suzuki steve's 410 build
- suzukisteve
- Suzuki Guru
Re: suzuki steve's 410 build
yeah the electric tape is a good idea Scott ill give it a bash!
pickle power!
I used synthetic enamel gloss from my local paint place. Stood up to the wiltshire hedges ok and never came off when i pressure washed it.
- suzukisteve
- Suzuki Guru
not much action at the moment im afraid as im off to the lake district tomorrow morning (unfortunately not in the zuke). so I thought id put a pic up of the sticker I just put on the bonnet instead
- 20130808_212232.jpg (2.07 MiB) Viewed 5153 times
pickle power!
- suzukisteve
- Suzuki Guru
im on holiday uo north at the mo (without the zuke
) but im still thinking of the next steps to take.
needs a good steam clean and underseal as half of whiltshire is still hanging on for dear life underneath. i can get it all done properly for around the 50 quid mark so thats cool. also gotta wire up the front spots and sort out a rear one as well.
could do with a lick of paint inside for a bit of protection as well if im honest.
some time next month ill be getting my 5 speed g/box and fwhs (thanks to the combined efforts of andyrew and scottie. cheers lads!) so ill chuck and clutch in at the same time as well.
there are a few little bits and pieces that need doing and tidying up but its all good fun!
cant wait to get cracking!
pickle power!
- suzukisteve
- Suzuki Guru
while I had two mins
- mmmmm snotty
- 20130828_151346.jpg (2.97 MiB) Viewed 5107 times
pickle power!
- Edweird
I can't decide if that's great or terrible!
- suzukisteve
- Suzuki Guru
im not sure yet either. its a bit of an experiment really to see how it goes. good fun tho
pickle power!
I like it. Just hope the paint doesn't burn off.
- suzukisteve
- Suzuki Guru
yeah ive given it s good hoon to warm it up. seems to be holding well but I think time will tell on this one.
I done a few other bits last night in prep for the next day out.
diff oils changed. they weren't overly bad if im honest. a little murky but ive seen worse. u also chucked a moly slip in for good measure
next was a nice oil and filter change as it was slightly overdue.
then came the cibie oscars I fitted a while ago. all wired up and a nice heavy duty switch just above the fog light switch.
- 20130828_195942.jpg (2.22 MiB) Viewed 5072 times
- let there be light!
- 20130828_195957.jpg (1.55 MiB) Viewed 5072 times
pickle power!
