gremlin
windsor
gremlin
Post by windsor » Sun Aug 18, 2013 1:50 am
Rite my m8s van had a cd player fitted when u press the horn you get no sound but the full beam light comes on and same thing happens with interia light. Theres a 2pin plug behind the clocks that doesnt go anywhere and and a green 4pingreen plugg that doesnt go anywhere behind the heater controls anyone help out
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
Re: gremlin
Post by Darrell » Sun Aug 18, 2013 11:07 am
But what's the Van ;)
Re: gremlin
Post by turbo-tom » Sun Aug 18, 2013 11:09 am
Samurai van I think. :)
Re: gremlin
Post by Tramp » Sun Aug 18, 2013 11:22 am
Ahhh I've had this, you take the two pin plug and there should be an orange sensor which it connects too, then the green plug behind the heater needs to go in the yellow socket also behind the heater.............
Honestly I don't know, do you mean when you push the horn it doesn't operate or that the CD player stops operating? If the radio stops it sounds like an earth fault, I'd run a new + & - cable for the radio
windsor
Re: gremlin
Post by windsor » Sun Aug 18, 2013 12:01 pm
Yeah the horn makes no sound just get a blue light inside tellkng u full beams on when u press the horn it weried cos av striped half the car back and traxwd all the wireinf back and vant find ant fault
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
Re: gremlin
Post by Tramp » Sun Aug 18, 2013 1:03 pm
We're on about an SJ here right? Does it have the horn on the stalk or in the centre of the wheel? It sounds like when you push the button it's making the switch to a common earth ( the full beam indication) but as the earth isn't there the voltage will pass through the indication lamp and earth on that side of the circuit, so it won't operate the horn as the horn will be only getting half volts do you see what I mean?
It should follow the red line but because that earth is damaged or has failed it will follow the green to get to earth
windsor
Re: gremlin
Post by windsor » Sun Aug 18, 2013 1:30 pm
Yeah on sj and yeah i get you thanks
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
Re: gremlin
Post by Darrell » Tue Aug 20, 2013 11:16 pm
Did you fix it ??
I've been having a look at the wiring diagram and to me it just looks like a blown fuse.
If you have switched earth headlights they have a constant live.
This means the highbeam indicator light also has a constant live.
With a blown fuse this makes makes an earth via the horn coil when pressed or the interior light bulb coil when the door is opened.
Mind you I could be talking bollocks :er:
fusebox 2.jpg (29.33 KiB) Viewed 6362 times
Re: gremlin
Post by ScottieJ » Tue Aug 20, 2013 11:20 pm
I've had that fuse blow before and it did some interesting things :lol:
Re: gremlin
Post by Edweird » Tue Aug 20, 2013 11:25 pm
Because of the slightly odd wiring on some of them they can do all sorts of weird things when stuff breaks. At one point my indicators also made my drivers side full beam blink.
