Tims SJ410 Build Project
Re: Tims SJ410 Build Project
Post by Jordi » Thu Nov 21, 2013 10:17 pm
Tidy work bud!
timwilks13
SCUK Website Padawan
Post by timwilks13 » Thu Nov 21, 2013 11:25 pm
This evenings update, front end off, engine and box out. Replacement engine cleaned a bit, swapped the dizzy fly wheel, clutch, gear box and starter motor across, tomorrow I will do the inlet manifold and alternator and get it put back in, and hope it runs better than the one I've taken out to please mister mot man. He didn't like the fact that I was burning so much oil he didn't even fully complete the emissions test as the garage was full of black smoke!
I'll put pictures up in a sec as my tablet has decided it doesn't want to let me.
timwilks13
Post by timwilks13 » Fri Nov 22, 2013 8:44 am
Pictures as promised, not very exciting im afraid, but still, progress all the same!
Post by ScottieJ » Fri Nov 22, 2013 12:43 pm
Looks like you have been having fun :doublethumbs:
timwilks13
Post by timwilks13 » Fri Nov 29, 2013 4:33 pm
replacement engine is in, tonight ill get her wired up and running hopefully, fingers crossed it doesnt smoke like a tyre on fire like the last one!
Post by Edweird » Fri Nov 29, 2013 4:45 pm
Looks like we're going to have to arrange another off-road weekend so we can tune it up again.
timwilks13
Post by timwilks13 » Fri Nov 29, 2013 4:49 pm
Edweird wrote:Looks like we're going to have to arrange another off-road weekend so we can tune it up again.
because the carb was set up quite well i have swapped the whole manifold over with carb attached and everything, so if i can get the engine tuned like the last one, fingers crossed there wont be much more tuning needed!
Post by twiss » Tue Dec 03, 2013 11:07 am
There may be slight variations in the tuning required with a different engine, but it shouldn't be too far off :)
timwilks13
Post by timwilks13 » Tue Dec 03, 2013 11:20 am
Yea im sure a bit of tinkering is required, however got another issue to sort first! Got the engine in the other night, wired up all the basics, starter motor, alternator etc and tried to start it to check it runs, got a click, a random spark or two and some smoke....not from the exhaust....somethings not quite right!
Post by Jordi » Tue Dec 03, 2013 11:35 am
timwilks13 wrote:Yea im sure a bit of tinkering is required, however got another issue to sort first! Got the engine in the other night, wired up all the basics, starter motor, alternator etc and tried to start it to check it runs, got a click, a random spark or two and some smoke....not from the exhaust....somethings not quite right!
Check all your main electrical connections, particularly battery and starter. Sometimes if these are super tight you don't get a good enough current. Especially if they aren't earthed very well.
