Short and sour!
Short and sour!
Met up with scottie earlier for a bit of snow fun......it lasted ten mins!
Twas my own silly arse fault......too aggressive when i got a little stuck and something went snap......thanx to scottie for towing me out of gran's.......but looks like i'll be off the road(not in the good sense) for a spell!
maybe a better run next time ay scottie!
my ride.........
my ride.........
Re: Short and sour!
wot you done
- jameswilts
Re: Short and sour!
Same here! I went out with Scott Saturday and something went snap!!
It was my rear prop!! What's up with yours?
Please help me find a new zook!!
Re: Short and sour!
sorry guys perhaps i just bring bad luck was a good lil bit of offroading before it happened though! i ended up just going for a drive to find the deepest snow i could in the end
Re: Short and sour!
First thought was the halfshaft, but scottie thought cv joint(i think......bad memory ) or something else...of which i forgot
but if its not too arctic out this wknd i'll try to investigate!..........hopefully its not a git of a job but i did go through some nICE water that probably has frozen eveything solid by now
But hey....thats mud truckin for ya!!!!!!!
my ride.........
my ride.........
Re: Short and sour!
i think it was a cv by the way you couldnt steer, the crunching was coming from the drivers side wasnt it?
Re: Short and sour!
I'm not sure.......i span both wheels after i jacked up the old girl and heard a slight rumble when i turned the passengers...so started takin off the wheel....then i selected 4l and 1st gear...(but i came to a question)...why could i still turn both wheels?
my ride.........
my ride.........
Re: Short and sour!
think scottie is right, i recently broke nearside cv joint, u will be able to spin wheels coz it is in effect a break in the drive line but the fact u say steering affected.
when the joint breaks the balls come out and jam the joint which restricts its turning movement.
exactly wot mine did, it had the turning circle of the QE2.
kev.
kev.
Re: Short and sour!
Boooooyaaa!!! Back on the road!
Twas the cv...i looked at my old axle as well and did the same break on the same side a year ago in the last snow outing!
so i took the driver side off the old axle and replaced the broken one on the sj!
GOOD TIMES
I think i may have to get a couple of spares just in case i do it again(which i probably will ). Might be worth fixing the other axle as well.......
anyway...... YEY ME
GOOD TIMES
anyway...... YEY ME
my ride.........
my ride.........
