hmmm think i might finally sort out rear discs...
Post by twiss » Mon Feb 17, 2014 2:33 pm
I've had all the bit to do this for some time now... old caliper mounts etc.
I have been waiting to try and get a decent kit with mounts in it but not sure I can be bothered now!!!
I'm gonna make the caliper mounts as in our guide... not been keen on the idea really with the new holes and a part missing, but I'm just going to bolt it up and weld it on I think ;)
Re: hmmm think i might finally sort out rear discs...
Post by andyrew » Mon Feb 17, 2014 3:02 pm
Got them brackets if you want em dude
Post by twiss » Mon Feb 17, 2014 3:04 pm
Thought you said they were the same as those? I've got a spare set of caliper mounts already so just need to drill the holes out :)
Ladaman
Post by Ladaman » Mon Feb 17, 2014 3:55 pm
I'm not sure if you will be able to weld them on, aren't they cast iron?
You might have to go with bolts only.
ferris
Post by ferris » Mon Feb 17, 2014 4:56 pm
I used that write up when i did mine. Its all pretty straight forward and works really well. The worst bit is cutting the disc holders out of the old drums, especially as i cut them the wrong size and had to do it twice.
Worth it just to get rid of those troublesome drums.
kiwizook
Post by kiwizook » Mon Feb 17, 2014 6:18 pm
I just got the local engineers to cut the drums out on the lathe. fit perfectly, perfectly balanced, and really easy, I definitely recommend them to be cut on a lathe
