Mudmenace's Purple 410
Hi im mudmenace from west sussex from used to use difflock and other forums quite abit have just brought a b reg sj410 as a new project looking to chatting and meeting some of you guys.
Re: newbie
Hi
to the club. Got any pics?
Re: newbie
- Ladaman
- Suzuki Guru
Re: newbie
C'mon, let's see some pics!
Re: newbie
It's the purple one haha
He's been on here before but with a range rover
- image.jpg (2.52 MiB) Viewed 7319 times
Re: newbie
Re: newbie
Welcome!
Re: newbie
more pics!
these are pre-cleanup and its looking better and better! more pics later
- 1779906_10153962065900122_1275679530_n.jpg (83.99 KiB) Viewed 7287 times
- 1965015_10153962066025122_1300257498_n.jpg (126.07 KiB) Viewed 7287 times
- 1932237_10153962065945122_323318689_n.jpg (115.58 KiB) Viewed 7287 times
- 1908232_10153962065855122_622074294_n.jpg (97.15 KiB) Viewed 7287 times
Re: newbie
i should add that all the sills and arch lips are in great condition, as are the joins between the front wings and arches... the only real rust in the engine bay is the battery wall bit, which has come off
theres a little bit of wiring to do, the oil pressure light wire has broken off, it needs new battery connectors (another good use for the vitara loom!!!)
needs a new headlight bowl as the pass side is full of water
the throttle disc is jammed so we're either going to take it off and fix it, or stick a HIF38 on it
Inside the dizzy cap is like new but we are still going to put a 413 coil and dizzy on it for good measure!
it needs new tyres but they are crappy road tyres anyway
