folded sills
- timwilks13
- SCUK Website Padawan
folded sills
My sills are all bent from being crashed into at both sides, was going to replace them with box section when i got round to it, but thinking instead just cutting off the seam at the bottom of the sill and folding the bottom and outer sill flaps back under themselves, so rather than having a channel style sill, it will be like an L shape, are there any disadvantages to doing this?
Re: folded sills
- timwilks13
Re: folded sills
Yea that looks good! Is the outer the original sill folded under? Or a seperate sheet?
Re: folded sills
Outer sill cut off and flipped upside down
I also like this alternative to box section sills, bit more work but more clearance and built in rub rails.
Re: folded sills
I like those! If I ever redo my sills, I'll probably do something like that.
Re: folded sills
I might do it on the longwheelbase, those sills are screwed.
- mike harris
- SCUK is my life
Re: folded sills
Easy, two L shapes spot welded together (plug weld if you don't have a spot welder)
Simple. Bosh.
Simple. Bosh.
- image.jpg (63.44 KiB) Viewed 6071 times
- mike harris
- SCUK is my life
Re: folded sills
Outer sill panels are £25 each
Bash them in away you go.
- timwilks13
Re: folded sills
Cheers guys, few ideas to be on with. Probably go with something i can just make as a whole mike so as to not spend an extra £50 if i can help it.
Re: folded sills
Tim I can always get you some outer sill panels folded up like the ones I have used on my fathers longwheelbase.
