starting problemes
Sue&Brian
starting problemes
Post by Sue&Brian » Tue Feb 23, 2010 8:40 pm
Hi can any body help ? I have an an intermitant fault on starting when i turn the key to start the odd time it just clicks as if the starter motor is jamed on the ring gear but but this is not the case if I switch of again it sometimes starts the next time and sometimes it takes two or more turns Regards Brian rainy Algarve
Henry
Re: starting problemes
Post by Henry » Tue Feb 23, 2010 9:25 pm
Hi Brian.
Very common problem, known as the clicky starter.
Have a look in the DIY section on how to fix, but i just hard wired mine through a push button. Now the push button has taken place of the last bit on the key turn.
chan
Post by chan » Wed Feb 24, 2010 1:23 am
i also have this problem and today its fixed self :)
if it starts again ill have to do the relay mod
cheers
Sue&Brian
Post by Sue&Brian » Thu Feb 25, 2010 9:29 am
Hi Thanks for the imfo Cant find anything in DIY Regards Brian Portugal still hissing down
Post by ScottieJ » Thu Feb 25, 2010 12:17 pm
the clicky starter fix wiring is on this diagram, note this diagram is for a jap sj however the cliky starter fix is still the same on a spanish
chan
Post by chan » Thu Feb 25, 2010 12:38 pm
thats a great picture! thanks alot
Ginger_boy
Post by Ginger_boy » Fri Feb 26, 2010 5:04 pm
Hi
yep had the same prob with mine and yes it also came and went quite mysteriously. have a look at this i wrote up for my Sammi it should helphttp://myweb.tiscali.co.uk/shillingworld/new_page_6.htm. :lol:
