Kawazonkey
- donkeychomp
Re: Kawazonkey
Thought you would! Bodywork will be in the same colour...
Re: Kawazonkey
donkeychomp wrote:Thought you would! Bodywork will be in the same colour...
- donkeychomp
Re: Kawazonkey
Rear wheel all finished and assembled. I am well chuffed!
- WP_20140620_003.jpg (1.46 MiB) Viewed 5103 times
- WP_20140620_002.jpg (1.52 MiB) Viewed 5103 times
- WP_20140620_001.jpg (1.15 MiB) Viewed 5103 times
Re: Kawazonkey
did you use that lawn repair kit for that?
- donkeychomp
Re: Kawazonkey
I fed the wheel carefully for 3 weeks, watering it occasionally, and it grew! Needs trimming though...
Rear wheel now freshly mowed and on!
- WP_20140622_001.jpg (1.45 MiB) Viewed 5088 times
- donkeychomp
Re: Kawazonkey
Now all the rear brake components are on. Took a bit of head scratching to work out where it all went!
Was going to fit braided hoses but the old ones are fine, and I'm broke...
- WP_20140623_004.jpg (1.42 MiB) Viewed 5073 times
- WP_20140623_002.jpg (1.49 MiB) Viewed 5073 times
- WP_20140623_001.jpg (1.52 MiB) Viewed 5073 times
- donkeychomp
Re: Kawazonkey
Put on the undertray in the subframe today. Curious thing, one indicator lens is clear and had some naff orange tape on it...took it home, masked it off and used an orange Sharpie to colour it in! It worked too!
- WP_20140625_004.jpg (1.35 MiB) Viewed 5061 times
- WP_20140625_001.jpg (1.44 MiB) Viewed 5061 times
- WP_20140625_003.jpg (1.41 MiB) Viewed 5061 times
- WP_20140625_002.jpg (1.47 MiB) Viewed 5061 times
- donkeychomp
Re: Kawazonkey
Put the gearshift bits on, it's rather close to the sidestand so a bit of adjustment is needed. The other part of the subframe plastic is on and you can just make out the indicator I 'coloured in' in the background...dangling there.
- WP_20140626_003.jpg (1.5 MiB) Viewed 5043 times
- WP_20140626_002.jpg (1.28 MiB) Viewed 5043 times
- donkeychomp
Re: Kawazonkey
Well it really chucked it down this afternoon, so I rebuilt and repainted the radiator (try saying that pissed) and it's all on and plumbed in. And a sneak preview of the bodywork...or Robbie porn as it is normally called...
- WP_20140628_006.jpg (1.56 MiB) Viewed 5030 times
- WP_20140628_005.jpg (1.45 MiB) Viewed 5030 times
- WP_20140628_004.jpg (1.43 MiB) Viewed 5030 times
- WP_20140628_003.jpg (1.54 MiB) Viewed 5030 times
- WP_20140628_002.jpg (1.44 MiB) Viewed 5030 times
- WP_20140628_001.jpg (1.52 MiB) Viewed 5030 times
