Locking rear diff.
- 1066 Boy
Locking rear diff.
Hi all, i have a lock-right rear diff lock. Its in with the other spare bits that
comes with the car. If i dont use it and want to sell it, whats it worth?
I Know how to work it. Not, how it works...............
believe me, there is a difference!!!
Re: Locking rear diff.
Jimnybits charge £226 for them new
- 1066 Boy
Thanks for that Twiss. So would £100 be to much s/hand
I dont want to take the p**s but i dont need it.
£100, if it's new, is taking the p**s - I would say £150 is more fair unless you want rid of it fast.
- 1066 Boy
I have the locking rear diff and the front one in the same ratio.
I want to get rid of the pair so open to offers.
What's the ratio? And I assume the front is an open diff?
- 1066 Boy
Yes the front is a normal diff. lock-right rear.
Not a clue about the ratio's as i am new to all this.
Mark a spot on the Crown wheel and a spot on the pinion. Slowly rotate the diff and count the number of teeth on each. Divide the number of teeth on the Crown wheel by the number of teeth on the pinion.
That's your ratio.
You'll have a tough time selling them without knowing the ratios.
That's your ratio.
- 1066 Boy
Thanks for that, i'll have a look at the weekend.
I am not that savvi with things like this but i'll have a go.
- 1066 Boy
Ok job done. They are 3.9's.
