weber carb tuning and info
Hello all, Just fitted weber carb to my 1.3 samurai. Engine runs well at speed but stalls when choke is applied. How do you adjust mixture? Well chuffed with it though seems to have improved throttle response no end
- Tramp
Re: weber carb tuning
this should help you out..
Nice one thanks! Hadnt spotted the idle solenoid so once thats connected things should run a bit better.
Just realised theres no idle solenoid on my weber carb for some reason plus no vacuum advance on the dizzy. Adjusted carb as per instructions and hey presto! runs an absolute treat
Promoted to sticky status that's some useful info there tramp.
I'll add some more thanks to our member V8disco who works for Weber.
"Here is a tip for you guys with a 32/36 DGV that cuts out on extreme inclines. Firstly, dont turn the carb round. If you do then you will get a huge flat spot as the fuel surges from the jets on acceleration. The problem is that, on extreme inclines the carb actually floods, so you need to reduce the amount of fuel. To do this, reset the float level to 14mm and go down from 200 to 175 needle valve and that should sort it. We dont do this on all of them as it is only a tiny percentage that are used on extreme angles and it would add parts and labour cost for all customers to change all of them."
Re: weber carb tuning and info
More useful Info for Weber carbs (Found on ACKs FAQ)
Weber Manual
32/36 installation guide
Weber trouble shooting guide
Weber Manual
Just installed a weber carb to my SJ.
My nikki carb needs a re-build. The cold start is knackered, the return spring doesn't work and it idles at 4000rpm...
I've installed it backwards (oops) but it seems to be running fine. Idles a lot nicer .
I just need to install a choke if I can be bothered, and work out a way of connecting the acellerator cable (this was modified for the nikki, and now needs to be modified again).
I was wondering if there is any issue with me running it backwards before I carry on. I've heard lot of stuff, better on hill climb, I shouldn't run it backwards but change some settings etc.
I also have no idea what jets are on it, and I don't have a fuel regulator installed. It is on the 1.6 engine. I was planning on connecting the accelerator cable and seeing how she drives. If all seems to be working leave it I suppose?
hi gusy i have a webber carb on my 1300 engine it was running fine then we went out for the first time it sounds like its sucking in to much air and feels like its loseing power i ajusted the fuel and air screw and it did run better for a few hours then started playing up again i had taped over the air box half way as i couldnt finish the snorkle in time and this helped with sucking in to much air then it started again then it would rev out clean it's got a missfire at full throttle eny one help ??
Updated Tramps pics with the higher resolution copies that he sent me (now hosted on our server)
- Tramp
Thanks Scottie, I appreciate it,
