"The rusty-nail" build
Re: "The rusty-nail" build
Doesn't look anywhere near as rusty as you promised, and it seems to have been welded/bolted together. I don't see any nails...
Top work, mate!
Top work, mate!
- ektoz
yes scottie those are 1988 SsangYong Korando stock leafs they were tons of those clone anus cj's here in cyprus, i got the leafs for 100 euro for all four they are very similar to the YJs i will go tommorow to work on the rollcage and i will tel you the exact mesures, thanks Anton and sorry for letting you down on this one but the name of the thread was at the start of the build now am going to a different name,
the theme on rig will be a mat olive army paint with the vietnam war white star on the hood and black tubes
I forgive ya, mate.ektoz wrote:thanks Anton and sorry for letting you down on this one
They flex well and that's almost the exact measurements of YJs!
Shame I've never seen a Korando that shape in the UK
- donkeychomp
Wish we could get away with that over here....
There are loads of corrando's over here.. Will go an measure up the springs! Cheers for the idea!
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
- ektoz
I have been working for 2 days now on the rear end and i closed everything with steel sheets weld them with co2 and closed them with mastic silicone for cars zuki is ready for spraying acid to clean the rust and power wash with hot water inside out for painting , there is no rust like in uk because it doesn't snow here.
sorry no pictures yet
Superb build, can't wait for the next lot of pictures, a rare old combination of parts used.
- ektoz
late update had some problems with the brake pump and i got it fixed i used nissans pulsar complete system
as you can see is nearly done and there is tons of little things as
rear lights, seatbelts, axle and tranfer case breathers, fixing the filter, install handbrake, and the list goes.
am plannying buying this http://www.ebay.co.uk/itm/290896092763? ... EBIDX%3AIT
what do you guys think??
pic time
pic time
