Off-Road Armoury Cage
mattmiles
Post by mattmiles » Sat Nov 29, 2014 8:51 pm
Evening all!
As some of you may know, I recently had some fabrication work carried out by Rob and Andy at Off-Road Armoury! Thought I'd just say what a great experience I had with them.
The cage is 6 point external, with an internal cross brace just behind the seats. Rob and Andy also fabbed up a rear winch bumper for me.
Would highly recommend them! :rockin:
(Pics attached)
Matt
Re: Off-Road Armoury Cage
Post by donkeychomp » Sat Nov 29, 2014 10:16 pm
Amazing work..amazing dosh.
I emailed them 5 years ago and they quoted a grand for something like that.
Looks very very nice though!
gamble63
Post by gamble63 » Sat Nov 29, 2014 11:52 pm
I was working there when your Sj was in, Loved having a good old nose around your truck, its great!
Post by twiss » Mon Dec 01, 2014 3:28 pm
Looks a lot better than the hash up of an engine swap they did for me 10 years ago :P
Seriously though truck looks fab :)
kiwizook
Post by kiwizook » Mon Dec 01, 2014 6:21 pm
what's under those two frontmost mounts? they put a brace down to the chassis or is it just bolted to the body?
RickUK
Post by RickUK » Mon Dec 01, 2014 6:40 pm
That is one nice looking motor,do you plan on adding a front winch as well or just keeping it with the rear one ??? out of interest why did you go for the rear option rather than a front mounted winch like most folks use ???
Deceased.
Current wheels.
mattmiles
Post by mattmiles » Tue Dec 02, 2014 11:47 am
Cheers for the comments chaps! Very happy with the way it turned out. :D
RickUK wrote:That is one nice looking motor,do you plan on adding a front winch as well or just keeping it with the rear one ??? out of interest why did you go for the rear option rather than a front mounted winch like most folks use ???
I'll be sticking with just the rear winch for now matey, like to keep it simple! There was no real logic as to why I went for a rear winch over a front. I wanted to add a rear bumper that could withstand a few nudges, and it would also be needed for the cage mount, it was a good opportunity to add a winch. I guess a bit of weight over the rear axle isn't a bad thing either.
Few more pics. The internal cross brace is bolted through the floor to the chassis, and through the roof to the centre loop.
Matt
Post by ScottieJ » Tue Dec 02, 2014 12:54 pm
looks good, what size is the tube?
mattmiles
Post by mattmiles » Tue Dec 02, 2014 1:25 pm
ScottieJ wrote:looks good, what size is the tube?
Hey matey,
Main tubes are 1 3/4", the cross braces on the roof and internal tubes are 1 1/2" I believe.
Have you decided what sort of size you'll be using on your buggy build?
Matt
Post by Anton » Tue Dec 02, 2014 1:27 pm
That's very nice work! Liking the internal cross brace, should make the whole thing much, much stronger!
