1987 Samurai half shaft bearings!
littlesammy
Re: 1987 Samurai half shaft bearings!
Post by littlesammy » Tue Mar 18, 2014 7:01 am
Are they actually called half shaft bearings as ive been all over flea bay and all i can find is wheel bearings.,?
cheers
liam
87 Samurai with added spice !
Post by dan_2k_uk » Tue Mar 18, 2014 8:17 am
They are wheel bearings
Ladaman
Post by Ladaman » Tue Mar 18, 2014 8:18 am
Half way down the first page of this link are the bearing and seal details.
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2801
The bearings are 6207, but there are other bits needed also, seal retainer etc... There are loads of bearings on eBay
littlesammy
Post by littlesammy » Tue Mar 18, 2014 9:29 am
Ladaman wrote:Half way down the first page of this link are the bearing and seal details.
thanks mate.,ill get what details i need from that and order a kit !
thanks
liam
littlesammy
Post by littlesammy » Tue Mar 18, 2014 9:30 am
dan_2k_uk wrote:They are wheel bearings
as if i wasn't confused enough , lol !
Post by ScottieJ » Tue Mar 18, 2014 9:51 am
Go on www.muddyzook.com for bearing kits
littlesammy
Post by littlesammy » Mon Mar 24, 2014 10:38 am
Doh ! hello gents, where do i get the square retaining plate as mine seems to be slightly oval.!! and whilst im in full retard mode , does the spacer supplied with my bearing go on first.,? i can't tell because what was left of the old bearing is half way down the axle in a million bits.!
luckily none of it was in the diff !
cheers
liam
Post by ScottieJ » Mon Mar 24, 2014 11:49 am
Muddyzook sell heavy duty bearing retainers, also sell split ones making bearing changes even easier.
The thin 4mm spacer goes on first, taper to the wheel end of the shaft, then bearing then locking collar.
littlesammy
Post by littlesammy » Mon Mar 24, 2014 11:58 am
ScottieJ wrote:Muddyzook sell heavy duty bearing retainers, also sell split ones making bearing changes even easier.
cheers mate.,i just bought the plates from muddyzook.
thanks for you help., its much appreciated., that apples to everyone.!
