Toyota props
Re: Toyota props
Yeah, accelerating hard in 1st, I get that same painful clunking noise. Bam bar should fix that.
Re: Toyota props
Looks like an ok angle to me, remove the prop to inspect the UJs properly, they might be dry.
Those are Sj props, they'll be fine, loads of us run the 1.6 on stock props with 33s and low gearing.
There's also the possibility that the clunk is coming from somewhere else, could be slightly worn Link bushes or one of the a-frame joints.
- donkeychomp
Re: Toyota props
Found the culprit today. A tbox mount is kanckered as is an engine mount. New ones ordered!
