Any idea what rims these are?
Re: Any idea what rims these are?
see on jimny bits it says
"These wheels look great on a Suzuki and the -30 offset is for those who want a wide stance without fitting wheel spacers"
but looking at your image it makes it look like we want a positive offset?
or am i looking at it wrong?
these were some old sj wheels i had and im guessing they are 0 offset
In that image the inside face of the wheel is on the left, the outside face is on the right. So -30 means that the wheels would stick out an extra 30mm further than 0 offset. Similar to getting 30mm spacers.
Bear in mind that if the rims are wider than the ones they replace, then 0 offset rims will stick out a bit further anyway.
ah that makes sense, thanks Anton, i will measure tomorrow and if all is good will order them
hopefully problem solved.
Thanks guys
Thanks guys
lol naturally they only have 1 in stock haha
Hey guys had a quick measure of the wheels on the truck today, i think i measured it from the right place and was getting 8" width and that i think is a 30mm offset. i know jimny bits sell 7" wide with the 30mm offset but i cant find any 8" wide, if i run with the 7" wheel is that going to be ok with the 31"x10.5x15?
Thanks guys
Thanks guys
You measure the wheel width from the inside of the lips so if it's 8" outside edge to outside its gonna be a 7" wheel.
Pretty sure I've got a set of 5 of these wheels I'll try and find a photo!
ah thanks Scottie that is great news, Callum im after 2 of them so that would ruin your set of 5. if you do have the same size with the 30mm offset and want to sell 1 id buy one from you and one from jimny bits.
cheers guys
edit** jimny bits are out of stock at the mo, dammit
cheers guys
