out of controll
Re: out of controll
No that gap between the spring bush eye and "military wrap" second leaf is fine.
Shorten the shackles/re fit standard ones then adjust the steering box play and check everything else.
Re: out of controll
Thanks how do I adjust the steering
Re: out of controll
While you have the shackles off, Id do the bushes as well
Re: out of controll
Just two more things I do have a wobble when I pull off but spots after ok around town just when I pull off and whats the best front and back seats I can put in the sj.
Re: out of controll
Up front whatever you can make fit, as for the rear I threw mine away
Re: out of controll
http://forum.suzukiclubuk.co.uk/vi ... =15&t=3310gratton wrote:Thanks how do I adjust the steering
Re: out of controll
Cool thanks swapping my bucket seats for some Ford seats now the wife might stop bugging me
Re: out of controll
If the steering box is more worn in the centre of its travel than the ends you have to me careful not to adjust it too far or it will be tight at lock.
Re: out of controll
Steering is all good now if I kick the front right wheel it makes a hollow sound I do have a spear axle in my shed it's off a sj but it's not the same as the one on my new sj it has wheel lock in the centre cap will it fit
Re: out of controll
What did you change/adjust to sort the steering?
All parts on all Sj axles from the knuckle seal outwards are interchangeable, the only bits that are different between models are the shafts, CVs, axle cases and diffs, but depending on the model said me of those can be swapped as well.
