Tyres
Re: Tyres
Post by twiss » Wed Jun 22, 2016 12:17 pm
As dan said you will probably pop them off the bead running 31s on 10" wheels.
I would sell them and buy some 8" wheels from 4x4tyres as jordi said. I think I got mine for £45 each?
Either that or keep them until you are ready to move to 33s
lukey4x4
Re: Tyres
Post by lukey4x4 » Mon Jun 27, 2016 11:28 am
Thanks twiss i did want 33 on so think i myt keep them , what would i have to do with the axels change them or are the 410 ones ok to run with 33 on , could i leave my spacers on so no rubbing aswell ? Thanks
Re: Tyres
Post by Jordi » Mon Jun 27, 2016 11:34 am
If you run spacers on those wheels and 33s you will destroy bearings.
Best thing is to swap to Samurai axles. Wider track, bigger diffs and more choice of diff gears to change your gear ratios.
Re: Tyres
Post by twiss » Mon Jun 27, 2016 12:14 pm
^ agreed.... samurai axles will give you more clearance between the tyres and springs too
lukey4x4
Re: Tyres
Post by lukey4x4 » Mon Jun 27, 2016 6:29 pm
Thanks lads seems like the best option then , how much r we talkin for the sammy axels n diffs n stuff , thanks
Re: Tyres
Post by twiss » Tue Jun 28, 2016 7:02 pm
Probably between £100 and £250 depending who you get it from and the condition. Bear in mind that the spring spacing on samurai axles is bigger so you will need to weld on axle saddles to match your springs :)
Re: Tyres
Post by ScottieJ » Tue Jun 28, 2016 10:05 pm
Don't forget you WILL need to sort the gearing out for 33s, it'll be crap with standard gearing and barely move or have enough power to make the most out of the tyre size.
Re: Tyres
Post by Jordi » Tue Jun 28, 2016 10:18 pm
33s, 4.1 t/box, 4.3 R&Ps
lukey4x4
Re: Tyres
Post by lukey4x4 » Sun Jul 24, 2016 8:54 am
Thanks for the help lads but think am just gunna go for the 31 for now , so just 1 quick question so i dont buy the wrong wheels or tyres lol , so i need some 15x8j rims and put some 15x10 or 10.5 tyres on and just to check would the gearing need to be changed still or would it be ok , thanks
Re: Tyres
Post by Anton » Fri Jul 29, 2016 11:53 am
ScottieJ wrote:Don't forget you WILL need to sort the gearing out for 33s, it'll be crap with standard gearing and barely move or have enough power to make the most out of the tyre size.
Ah, I don't think it'd be that bad on standard gearing. I'm on standard gearing with my 31's and 1.3 litre, and while it's not great, it's do-able. He's got a lower t-case than the one I have installed, plus he's got a 1.6 SPI.
I won't argue that it's ideal (that's why I bought a rockwatt rocklobster from Mike) but I wouldn't be *that* worried about a 410 t-cased 1.6 on sammy axles.
My plan is to go 1.6, rocklobster, and 3.9 diffs, but I've already got those bits lying around waiting for me to catch up...
