RUF Troubles, Please help :S
Re: RUF Troubles, Please help :S
Post by mike harris » Fri Jun 09, 2017 8:04 pm
Mine would be 1.5 inch lift pal
Online
Post by Anton » Fri Jun 09, 2017 8:29 pm
Jordi wrote:Half a day to a full day if you are using a kit. I used the sky kit from low range off road, few have used the trail tough kit. Scotties is home-brew.
Just had a look at that (in case I ever get the time/energy/money) and quickly realised it won't fit my 413, it's sammy only. I guess if I ever do it I'll have to borrow (steal) Scottie's design and make my own.
SlimGrim
Post by SlimGrim » Fri Jun 09, 2017 8:35 pm
mike harris wrote:Mine would be 1.5 inch lift pal
Ahh sorry I misunderstood, thought you said 5 inch springs, I'm still confused though, so you could make up some front springs for me or... My mind is fried today pls help haha
___________________
SlimGrim
Post by SlimGrim » Fri Jun 09, 2017 8:37 pm
Jordi wrote:
SlimGrim wrote:That's not a bad shout, Scottie how quick do you reckon I could change them over to YJ setup as its my daily so I'd need it for work..
Ahh that's not bad idea but fuck me they're pricey kits and that's before u buy springs too xD
___________________
SlimGrim
Post by SlimGrim » Fri Jun 09, 2017 8:42 pm
Hang about, I think I've wrapped my head around this, you buy 5" leaf Spring packs, then split them into single leafs and sell them as sets that are rated at more like 1.5 inch instead of 5" w/ 5 leaves.
Are single leaf springs safe? Seems odd to visualise in my mind haha
___________________
Post by mike harris » Sat Jun 10, 2017 5:57 am
So I basicly take a set of good standard springs and add ones extra leaf from the lift springs.
Where I only use one of the lift springs leafs under load it will be about a 1.5 inch lift spring.
But the leaf I use I make it as long as possible from a rear spring so the whole leaf is supported.
Il make some and if you don't fancy them il eBay them mate.
Post by Jordi » Sat Jun 10, 2017 11:00 am
Did you try Llama 4x4 for springs? I got some from him and they were spot on.
Post by mike harris » Sun Jun 11, 2017 11:51 am
The springs look the same as standard ones, front and rear are the same but have a leaf in each from a lift spring.
Mike
Post by mike harris » Sun Jun 11, 2017 11:53 am
I tried lots of differnat springs on my suzuki over the years, iron man, calming, llama
And old man emu in my humble opionion are by far the best. Il send you some pics of what those springs are caperlble off, incredible springs man !
SlimGrim
Post by SlimGrim » Mon Jun 12, 2017 2:26 am
Awesome cheers bud, how much would a front and rear set cost?
___________________
