How fast ?
Re: How fast ?
Post by Tramp » Mon Jun 19, 2017 12:46 pm
Mines slow like this 50-55mph tops, Mines a Weber too, I'm seriously considering a carb swap
Re: How fast ?
Post by ScottieJ » Mon Jun 19, 2017 1:40 pm
What size tyres are people running? If 235/75 or similar then a 410 tbox will correct the gearing.
Really an SJ should easily to 60-65 so its going to either be gearing or the carb set up, a weber if jetted and tuned correctly should easily hit more than 55.
Also remember bigger tyres put the speedo out so you will be going faster than what the speedo says.
Re: How fast ?
Post by andyrew » Mon Jun 19, 2017 1:58 pm
Tramp wrote:Mines slow like this 50-55mph tops, Mines a Weber too, I'm seriously considering a carb swap
50-55 comfortably with my weber or flat out clinging for dear life 90 indicated and deafness.
SlimGrim
Re: How fast ?
Post by SlimGrim » Mon Jun 19, 2017 7:46 pm
As said, with my zuk samurai mines basically stock engine stock wheels, Toyota carb, runs 55-70 all day anywhere, and on bigger roads with a slight downwards slope can easily hit 80-85 tops
___________________
Re: How fast ?
Post by Anton » Mon Jun 19, 2017 11:40 pm
Mine has standard gearing and an SU carb on the 1.3, and 31" tyres. Should be terrible, but it's not. Does 70mph without *too* much trouble, on the flats/downhill - but forget about that uphill. 60mph is about tops uphill, if I'm lucky.
This is according to GPS (DigiHUD Speedometer), not my speedo.
Re: How fast ?
Post by twiss » Mon Jun 19, 2017 11:57 pm
Anton wrote:Mine has standard gearing and an SU carb on the 1.3, and 31" tyres. Should be terrible, but it's not. Does 70mph without *too* much trouble, on the flats/downhill - but forget about that uphill. 60mph is about tops uphill, if I'm lucky.
I think the special tracks do actually help, less friction maybe?
Re: How fast ?
Post by Anton » Tue Jun 20, 2017 12:09 am
I suppose that's a possibility, but I used to have those 31" road tyres and the only difference I could see was better braking and far, far less noise. I did very few miles on those things, though.
Re: How fast ?
Post by ScottieJ » Tue Jun 20, 2017 10:51 am
Twiss that logic is really flawed :lol: There's no way special tracks or any aggressive tread pattern will help.
Yes there might be less surface area contact with the road but there's a big increase in the rolling resistance because of the large gaps in the tread.
Re: How fast ?
Post by ROBBIE » Tue Jun 20, 2017 5:48 pm
Had 80 out of the old one on 31s, that was 1.6 with standard carb, not the best journey. Sat happy between 50-60 but the noise wasn't good
Robert.m
Re: How fast ?
Post by Robert.m » Wed Jun 21, 2017 10:12 am
I found an air leak in one of the breathers making it run a little lean, fixed that and now it seems happy at 50 - 55mph, which I am happy with.
It still sounds like it is drawing air in somewhere from around the inlet side of the engine but can't find exactly where.
