Page 2 of 2
Re: disc handbrake
Posted: Tue Feb 09, 2010 8:57 am
by carnut
Check my last post??? i didnt read it all!!!..
you may have to hire, beg steel etc a puller. that what i used to remove my flanges so i could strip my transfer box..
Re: disc handbrake
Posted: Tue Feb 09, 2010 10:31 am
by chan
carnut wrote:Check my last post??? i didnt read it all!!!..
ahh well i will try removing it with the prop shaft first! i have a selection of pully pullers but not sure if the biggest one is big enough!
Re: disc handbrake
Posted: Tue Feb 09, 2010 5:52 pm
by carnut
on the rear of the backplate, there are two nuts and opposite two bolts, these hold the adjuster in situ. unbolt these and callapes the brakes??. but i reccon its the drum tight on the splines..
Re: disc handbrake
Posted: Tue Feb 09, 2010 6:17 pm
by chan
carnut wrote:on the rear of the backplate, there are two nuts and opposite two bolts, these hold the adjuster in situ. unbolt these and callapes the brakes??. but i reccon its the drum tight on the splines..
yeah i think its just the drum ceased onto the splines! was suppose to do it today but it took me 4 hours to get a half shaft out my rear axle as the bearing was completely ceased! i had to make a slide hammer out of an old steering arm and a pair of bike handle bars
after all that it wouldnt budge! i was going to try and yank it out with my range rover but thought it might be overkill
![Neutral :|](./images/smilies/icon_neutral.gif)
ended up turning the drum around getting a crowbar about as long as the River Thames on one side then hitting with a sledge hammer the otherside! almost fell of its axle stands the poor thing haha
![Razz :P](./images/smilies/icon_razz.gif)
i will have a look at the handbrake tomorrow when i get the rear axle back together!
if i cant get the drum off the transfer box i will just leave it and use the hand throttle for hill starts haha
![Mad :x](./images/smilies/icon_mad.gif)
Re: disc handbrake
Posted: Tue Feb 09, 2010 6:50 pm
by carnut
if you cant move it, and havnt got the tools.. i would leave the rear prop off, drive to a local garage and get them to put a puller on it,?? might cost you a drink, but its better than wrecking the drum..
Re: disc handbrake
Posted: Tue Feb 09, 2010 7:44 pm
by chan
id love to do that mate but it has no seats in it and a bit of wiring and my air box needs to be fitted ect also have no insurance yet! i like to do everything myself so if i cant get it off ill leave it for now until i can take it up the yard and get my gas torch on it. cant even bloody tow it up at the moment with no wheels on the back
Re: disc handbrake
Posted: Fri Mar 05, 2010 4:46 pm
I changed my mind about this X-eng handbrake! it used to work fine but now its doing my nut in after destroying another set of pads and not releasing properly!! I am going to try and modify it to make it work better and if i do i'll post the progress!
Re: disc handbrake
Posted: Fri Mar 05, 2010 5:18 pm
by carnut
ive just gone back to the drum handbrake??. i bought two new handbrake cables for my sammy,, £48 so ill be selling them,, reason is im going to rear disc it.
Re: disc handbrake
Posted: Fri Mar 05, 2010 6:11 pm
by Henry
