Page 2 of 5
Re: Wiring diagrams
Posted: Sun Jun 10, 2012 9:54 pm
by Darrell
I just use "photoimpact 10". Only because it came pre-installed on my last PC.
Re: Wiring diagrams
Posted: Sun Jun 10, 2012 10:07 pm
by Darrell
Just had a look at that fuse. I've added it as the acc supply from the ignition switch to the radio and ciggie lighter.
Re: Wiring diagrams
Posted: Wed Nov 28, 2012 11:05 pm
by Darrell
Vitara SE1600 wiring diagram - From the workshop manual (1994 Print)
Re: Wiring diagrams
Posted: Mon Jan 07, 2013 7:43 pm
by Darrell
Vitara SE1600 wiring diagram (injection model) - From the workshop manual (1994 print)
Vit inj wiring diagram.jpg (2.4 MiB) Viewed 54420 times
Re: Wiring diagrams
Posted: Mon Jan 07, 2013 9:45 pm
Awesome nice work Darrell :thumbup:
Re: Wiring diagrams
Posted: Fri Jul 05, 2013 11:11 pm
by ajowin
I'm looking for the wiring diagram for the heating control panel for my B reg SJ410. If anything a photo showing the wire connection to the levers would be really useful. The wire connectors are circular! :doublethumbs:
Re: Wiring diagrams
Posted: Fri Jul 05, 2013 11:44 pm
The only part of the heater control panel that has electrics is the fan speed switch, the rest are cable operated mechanical linkages. What is the problem with it?
Re: Wiring diagrams
Posted: Sat Jul 06, 2013 4:18 pm
by Darrell
Are you after the cable linkage diagram rather than the wiring diagram ??, sounds like it :er:
Found this for a 83-84 model. The dash with the rotary speed control.
Re: Wiring diagrams
Posted: Fri Jul 11, 2014 11:43 am
by baratten
Does anyone have a wiring diagram for '82s Samurai? Its different from the later ones, has a completely different fuse box.
Re: Wiring diagrams
Posted: Fri Jul 11, 2014 11:30 pm
by Darrell
:welcome: to the club
Is it the type with just 4 cylindrical fuses.
I have a diagram in the workshop manual, although the join across the pages is not very clear.
I could try to photograph it and join it.
