cherry bombs exhausts
- dazerede
Re: cherry bombs exhausts
I'm just wondering as I want a cherry bomb to put on my 410 can I keep the front silencer and remove the rear silencer and then add the cherry bomb Chears
4” calmini lift kit
4” calmini lift kit
Yup!
Just a case of find the right size cherry to fit the cap or get some exhaust pipe to fill any gaps.
- turbo-tom
Yep that will work i have the standard first box (want to get rid of it!), then it pipe all the way up to my backbox which is similar to a cherry bomb but it roars more rather then bangs like cherry bombs.
Just cut the flange off the back end of the front section and make up some exhaust to take it to a cherry squeezed in next to the fuel tank.
As said just match to your pipe
- dazerede
Re: cherry bombs exhaustsk
Chears guys I don't.want it to be too load
I took the back bit off of my exhaust as the exhaust is in 2 sections fired it up and wow it was load so I might try just putting the cherry bomb on it to see how good it is if its crap I will only have 1 silencer and a cherry bomb on it
4” calmini lift kit
4” calmini lift kit
- turbo-tom
Mine sounds like a tank with just the manifold! sounds allright just way over the top
- dazerede
I'm not sure to keep the rear silencer on or remove it
It would be quicker to keep it on
Does a cheery bomb act as a silencer a bit or not
As it was too load with just the front silencer on it
Confused
Confused
4” calmini lift kit
4” calmini lift kit
- turbo-tom
Keep all the exhaust system. But chop the rear box off and replace it for a cherry bomb. That way it will be quietish on tickover but when you put the pedal to the metal it will go deeper and probably pop n bang a bit
- dazerede
This is wat my exhaust looks like
If I remove the rear box it will take longer to make
- 2013-06-21_07-01-01-1.jpg (10.6 KiB) Viewed 5565 times
4” calmini lift kit
4” calmini lift kit
