doubts...
Henry
Re: doubts...
Post by Henry » Sat Jun 11, 2011 2:40 pm
twiss wrote:See I reckon it would go a bit faster without the rocklobster... as I believe the ratio for 2H is still different to that of a samurai t-box
Think the rocklobster drops high box by 70%
I had 57 out of mine flat out down a 2 mile dead straight :cry:
Saying that i had about 7psi in my tires.. :guns:
Henry
Re: doubts...
Post by Henry » Sat Jun 11, 2011 2:41 pm
Think the rocklobster drops high box by 20%
Re: doubts...
Post by ROBBIE » Sat Jun 11, 2011 5:49 pm
the old beast can do over 70, But the noise is horrendous
cherry bomb middle box cherry bomb back box insa special tracks,over 50 you cant even hear the stereo
Re: doubts...
Post by ScottieJ » Sat Jun 11, 2011 5:55 pm
what size tyres do you run russ?
if no more than 31s i'd say go back to spua but with rear springs up front and a small shackle lift in the rear to compensate for the height difference. (did i just say that :S lift shackles :?: yeah i did, on the rear i think little bit of extra length wont hurt too much!)
Re: doubts...
Post by twiss » Sat Jun 11, 2011 8:17 pm
I've still got shackles on the back of mine still. Its not really a problem because by the time they hit the floor you're normally well on your way through the obstacle ;)
Re: doubts...
Post by turbo-tom » Sat Jun 11, 2011 9:22 pm
or get calmini suspension but thats silly money , rock hard on the road (so thats the stable issue sorted out ;) ) , and run grizzlys 31inch , and drive with ear defenders on ;) :brows:
Re: doubts...
Post by ROBBIE » Sat Jun 11, 2011 9:30 pm
twiss wrote:I've still got shackles on the back of mine still. Its not really a problem because by the time they hit the floor you're normally well on your way through the obstacle ;)
so have i and ive got rhino rays reversal kit up front the same as you russ
Russ24
Re: doubts...
Post by Russ24 » Mon Jun 13, 2011 11:26 am
i run 215 15 diamond backs.
no good on the road.
with SPOA....
got a standard set of steel rims with standard tyres.. off a vitara... but also got a set of chrome-ish rims with 245 road tyres... look like bubble tyres.
revert back to SPUA.... i dont want to upgrade the size of the engine as i have recently as in the beginning of the year forked out for a moded manifold and an SU carb.
anyways i wouldnt put a petrol in again.. i would go with diesel.
looks like im stuck with the 45mph for awhile.
:russ:
Re: doubts...
Post by ScottieJ » Mon Jun 13, 2011 12:06 pm
so your tyres are around 28" tall then, in that case you don't really need any lift at all and I dont understand why you can only do 45mph? my 970cc lump with a 410 tbox & 30" tyres would hit 70mph easy enough :smokin:
keep the 413 tbox as it is higher geared than a 410/lobster box(so lower revs at a higher speed) and get your air/fuel ratio and timing checked.
Something really isn't right if you can only do 45mph :er:
Re: doubts...
Post by twiss » Mon Jun 13, 2011 12:13 pm
Russ, bring your zooki down to mine and we'll check in with the colourtune and the EGA
