SUZUKI SAMURAI 1300 VIBRATING PROBLEM
Re: SUZUKI SAMURAI 1300 VIBRATING PROBLEM
When I bought my little baby it shook like hell - found the rear prop u.j. yokes out of alignment on the sliding joint, might be worth checking your front prop if it's been apart.......
Yeah thats a good call! If they are out of phase it will have some bad Vibes as the UJs will be working against eachothermolehill wrote:When I bought my little baby it shook like hell - found the rear prop u.j. yokes out of alignment on the sliding joint, might be worth checking your front prop if it's been apart.......
think ive found the problem..the gear box mount has broke on the rubber part
I should have a gearbox mount in the workshop, ill have a look for you
