Page 2 of 4
Re: does a 413 head fit a 410 block?
Posted: Sun Sep 23, 2012 4:42 pm
by turbo-tom
410 i know you gotta change the engine mounts as if i remember rightly scott had to change his when he first done his conversion ;)
Posted: Sun Sep 23, 2012 4:46 pm
by Edweird
Jay18 wrote:im not sure abour skinny prop though?
What year is your SJ?
If it's a type 1 or 2 (pre-'85) It will undoubtedly be a skinny prop version. After that though things get a bit dubious.
Posted: Sun Sep 23, 2012 5:09 pm
by Jay18
mine is the 1987 model...
Posted: Sun Sep 23, 2012 5:13 pm
by Edweird
I'd say it is PROBABLY a fat prop then, but don't rely on my guess being right.
Re: does a 413 head fit a 410 block? + 1.6 8v fitting into 4
Posted: Sun Sep 23, 2012 5:48 pm
by Jay18
its the same thickness as the shaft from the Tbox to the rear diff with the handbrake drum on it... about 2/3 inch thick?
Posted: Sun Sep 23, 2012 5:54 pm
by Edweird
Sounds like a skinny to me then. That's what I'd guess mine to be too.
Posted: Sun Sep 23, 2012 8:14 pm
by Darrell
Shall we start a list.....
1600, engine + carb + radiator
1300, flywheel + clutch + gearbox + Sump? + oil pick-up pipe? + skinny starter
Make new engine mounts and gearbox mount
Have read the gearbox tunnel needs modifying ???
Does the short prop from the 413 go straight onto a 410 transferbox??
I assume you weld the engine mounts to make the short prop the correct lenght???
Exhaust , which one???
Well it's a start. Feel free to copy paste and add bits or edit my balls-ups :D
Posted: Sun Sep 23, 2012 8:58 pm
by Jay18
haha thanks for the help lads, might end up being a bit of a expensive mod to my sj, well see what happens might just end up upgrading to a jimny, well see...
Posted: Tue Sep 25, 2012 9:27 am
it's all in the engine code.
All F series engines have interchangeable heads and blocks
All G series engines have interchangeable heads and blocks
an Fseries head won't fit a Gseries block and vice versa
If yours is an 87 then all you'll have the fatter props fitted (skinny are only about 1" in diameter)
You'll need to modify the drivers side engine mount and as Darrell says. no other mounts or the transmission tunnel should need modifying.
1300, flywheel + clutch + gearbox These are not essential but save a dent in the sump and grinding the engine block > Sump? + oil pick-up pipe? + skinny starter
Either a 1300 or 1600 exhaust or make your own.
Posted: Tue Sep 25, 2012 11:51 am
by Jay18
thanks scottie! been trying to find out extactly what i need to do the conversion lol....
