my little project
- stevepsj413
Re: my little project
hi all thanks for ur words of support, yeah im gonna weld some box section between the floor n chassis to stop any rattles and im puttin the back seats back in as well so drill through floor n the box n weld captive nuts on the back so the seats are fixed nice and strong and not just through the thin floor, just need some box section so far ive not paid a penny for the steel ive used and i dont want to start now! ill add more photos as progress happens, cheers
Can't beat free steel! I love it!
- turbo-tom
Free metal is a bonus! i advertise for a local metal works and i get free off cuts of anything and i get dirt cheap metal aswell
- littlesammy
- stevepsj413
finally finished welding my sj, put bracing under the floor for more strength and fixed rear seats thru this too, seats seem to be well solid now, gave it a good old coat of schutz, it may delay the rust worm for a bit. Got a weber carb and had to make an adapter plate to mount it to the manifold, i wasnt going to pay 40 odd quid for 1 when i had a bit of steel knocking about! while on with that i made an air box adapter so i could use my standard one, engines running best as i can get it, top ends tappin like mad, think it needs a top end re-build but ill have to see how it goes. Booked mot for half 8 tomorrow, last 1 ran out in 2010, keepin my fingers crossed, with a bit of luck i mite be all legal by this time 2moz!
- DSC_0117.jpg (433.85 KiB) Viewed 5675 times
- DSC_0110.jpg (407.9 KiB) Viewed 5675 times
- DSC_0108.jpg (466.45 KiB) Viewed 5675 times
- DSC_0099.jpg (380.71 KiB) Viewed 5675 times
- DSC_0105.jpg (383.99 KiB) Viewed 5675 times
- DSC_0101.jpg (402.59 KiB) Viewed 5675 times
- Bracing under rear floor with seats fixed thru it
- DSC_0100.jpg (403.53 KiB) Viewed 5675 times
Looking good bud.
Hiya mate, Loving the SJ! Looks really good work. Did she Pass?!
Looks great mate well done you even have rear seat belts i need some of them !!!
- stevepsj413
failed mot. 1 rear wheel bearing and h/c emissions thru the roof got new plugs, leads, inlet gasket and a wheel bearing on the way, better luck next time
