SJ 410 tin top rear seat belts
windsor
Re: SJ 410 tin top rear seat belts
Post by windsor » Thu Jun 06, 2013 6:42 am
No problem hope these help if u need any more just ask
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
windsor
Post by windsor » Thu Jun 06, 2013 6:43 am
Allso mine is a import so could be the reson
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
SteveR
Post by SteveR » Thu Jun 06, 2013 8:37 am
Thanks again Windsor. Going by your pic just what the doctor ordered.
that mounting point or rear wheel arch, I have not got one, any chance of photo under the carpet. Guess there must be some sort of plate inside and one under wheel arch. Could you have a look to see how done as that point is not normally ideal for a seatbelt mount point. Do you recon it is original suzuki work ?.
thanks
Steve
SteveR
Post by SteveR » Thu Jun 06, 2013 8:39 am
Sorry to go on but go to get this right as it is for my little kids so no mistakes allowed.
Steve
windsor
Post by windsor » Thu Jun 06, 2013 11:54 am
Dont worry about it steve ill have a look for you
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
windsor
Post by windsor » Thu Jun 06, 2013 7:03 pm
Bolted throgh the arches
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
Post by dan_2k_uk » Thu Jun 06, 2013 9:06 pm
Well I never. Must be a rare option!
penpontgreenwoodwork
Post by penpontgreenwoodwork » Fri Jun 07, 2013 7:35 pm
Put a pair of SJ front 3 point inertia belts in the back of mine yesterday. Spool half way up, pivot above that (as in pictures above). End of belt fitted to prethreaded hole about 2" away from rear body mount. Mine had had a plate welded in the rear corner covering the hole but the captive nut could be seen from beneath so I could measure where to drill through the plate from above. I'd guess all SJ's must have these holes, they're inline with the belt socket mounting holes in the centre. Hope this is helpful.
They don't make cars like they used to!
SJ 413, tin top.
Sammy front axle.
2"? lift Springs on front, shackles on rear.
On the road
SteveR
Post by SteveR » Sun Jun 09, 2013 12:20 pm
thanks for the input guys.
Now I understand how to do just got to find some good used belts of right length.
Will be putting inertia types in using the already there four bolt holes along rear of floor by door and 3 on each rear side panels.
will be at least a couple of months as away but when I get it done will post pics.
Steve
