Hello from Essex coast
Re: Hello from Essex coast
Post by Edweird » Sun Sep 08, 2013 5:55 pm
Sj410red wrote:It can be a hand full at speed on cornering, bit jumpy, but hey its not built for doing much of that. And yes its motd and taxed.
Fair enough. Sounds like the caster is negative then but if it's only really an off-road toy then it's not that big of a deal.
OllieSJ
Post by OllieSJ » Sun Sep 08, 2013 6:09 pm
why dont u do what iam about to do have a nice every day few small mods sj with a trailer and a full off road parts / who cares what happens to it sj :)
Sj410red
Post by Sj410red » Sun Sep 08, 2013 6:30 pm
yes, i have got another sj but it needs a body as its 1 is shot, the chassis , engine and boxes r all ok, so thats is my next project, I was thinking of a blitz body kit, or a old suzuki carry van body, any ideas?
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Diff & Box high breather pipes
Front Diff guard
OllieSJ
Post by OllieSJ » Sun Sep 08, 2013 7:14 pm
Mate best thing is make its a buggy roll cage with the dash left in and boom a well nice buggy
Post by Edweird » Sun Sep 08, 2013 7:25 pm
Not a bad shout from Ollie.
The body on your red one looks good. Is the other one you've got fairly standard? If it is, I think what I'd do is a body swap and have one nice road SJ and then make a tube-bodied trailer queen out of your off-road one.
Sj410red
Post by Sj410red » Sun Sep 08, 2013 7:36 pm
The red 1s body is fairly good, usual welding in rear corners and front footwells, rear door was welded shut by previous owner, the door looked like it had tried to tow summit, had to reverse it back into padded wall to straighten it out, to push door back straight! The arches and sills are hammerited as there is rust and flakey paint in places, no carpets and tatty seats, apart from that she's a peach lol
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
Post by turbo-tom » Sun Sep 08, 2013 9:36 pm
welcome.
Post by ScottieJ » Mon Sep 09, 2013 10:03 am
:welcome: to :suzuki: clubUK, nice little SJ!
You don't need two SJs :lol: just enjoy it!
I would loose the shackles, they really give no benefits over standard length shackles. just lots of negatives including reduced approach and departure angles, bad caster angles and can induce more axle wrap. The longest shackles I would personally fit on an SJ with standard length springs (lifted or standard) would be 100mm bolt centre to bolt centre. lift is over-rated ;)
Also now you have lift springs don't forget to lower your bump stops :thumbup:
Post by Anton » Mon Sep 09, 2013 10:45 am
Welcome!
Those look like relatively "normal" sized tyres you have on your SJ, does it need the dragon's teeth shackles? I'd have thought it would perform just lovely with standard shackles, you look a bit high to me.
Sj410red
Post by Sj410red » Mon Sep 09, 2013 9:12 pm
I have got 2 extended bump stops still to fit, they came with the springs, the tyres fitted are 235/70/15 on standard 5.5j rims but I would like to add larger tyres, anyone know what max tyre size can fit to my rims are?
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
